Holley 4237 with auto 78?
Sep 30, 2007 | 04:10 AM
I wondering what the pro's and con's are to putting on a holley 4237, it has mechanical secondaries. Ive got a 78 auto vette
cheers
Dave
Sep 30, 2007 | 06:05 AM
find it at the curb on trash day?
i cant find that #
whaT IS IT?
Sep 30, 2007 | 07:00 AM
Quote:
Originally Posted by
Matt Gruber
i cant find that #
whaT IS IT?
lol, a very kind person gave it to me
its a carb from the early 70's, its a double pumper, a direct replacement for the Q-jet, bolts straight on, mechanical secondaries, etc
dave
Sep 30, 2007 | 07:14 AM
sounds very good so far.
any other #'s on it?
Sep 30, 2007 | 08:23 AM
Matt Gruber
it has "6R 4237 B", on the main body, it has 8522/6210 on one end and on the other end, it has 7866/6240(6 or 5)
thats all the numbers I can see, I did a search on google for it, a few threads come up for it
dave
Sep 30, 2007 | 09:30 AM
Sep 30, 2007 | 02:33 PM
Matt Gruber
its from a manual car, mines a auto, what happens for kick down wire?
is this carb ok for a auto box, in terms of driving the car??
what kit?, where from?
cheers
dave
Sep 30, 2007 | 03:01 PM
From: Graceland in a Not Correctly Restored Stingray
Stay with vac 2nds on your automaitic to avoid the possibilities of drivability issues.
Sep 30, 2007 | 03:17 PM
agent kronus
cheers
dave
Excellent for automatic. have to hook up cable/switch
Kit from auto supply or jegs/summit. 37-605 renew kit
Sep 30, 2007 | 03:21 PM
6210, 650cfm spreadbore should be set up for a good street carb.
holley renew kit #HLY-37-605, $32.95
www.summitracing.com
Sep 30, 2007 | 04:03 PM
Matt Gruber
is there a hook on the throttle linkage ready to take auto kick down cable, or do have to put something on it?
TheSkunkWorks
could you give me some details in what your meaning?
cheers
dave
Sep 30, 2007 | 04:33 PM
Mechanical 2nds typically work better on high-perf engines with manual transmissions. Mechanical 2nds on heavy automatics with standard engine performance can tend to have a hole in throttle response, as if "over-carbed". A properly tuned vac 2nd carb avoids this.
Sep 30, 2007 | 05:20 PM
agent kronus
you have both! u tell us! if u can't hook up the trans, skunkworks is right! big hole!
Sep 30, 2007 | 07:24 PM
ok, thanks info everyone
dave
