Help ID a Rearend
Old Sep 30, 2007 | 12:03 PM
435/427BB's Avatar
435/427BB
Default Help ID a Rearend
#s on bottom are AWW099E 2 Took it from a 74 and it has the cap style side yokes. Think it's a 3.08 but don't understand date or big block style side yokes. Thanks for any help.
Old Sep 30, 2007 | 12:06 PM
tjhuyser's Avatar
tjhuyser
the yoke generally won't identify ratio...mark a line on the front yoke and the housing (like morking a dist.) then do the same of the side yoke..as you count the number of revolutions you turn the front yoke to get the side yoke one revolution...that'll give you the ratio..
Old Sep 30, 2007 | 12:11 PM
435/427BB's Avatar
435/427BB
Thats how i figured a 3.08 but did 74 use this type side yoke are is it from another year? Is it an earlier BB rear?
Old Sep 30, 2007 | 12:40 PM
wfo76's Avatar
wfo76
Sometime in the early 70's (73 or 74), all cars started to get the big block style yokes with the caps and by 75, all cars had the larger 3" halfshafts also.
Old Sep 30, 2007 | 12:46 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
according to Corvette by the Numbers, Alan Colvin ...
AWW099E2 breaks down to:
AW = factory original 3.08 (1968 - '69 - '71 - '73 or '75)
W = Warren Michigan assembly plant
099 = julian date (april 9 is 99th day of year) and julian date started with 1971 rear end production, so this would be '71,'73 or '75.
E = Eaton positraction
2 = 2nd shift
PS - in his book, 1974 is missing the 3.08, so I suspect AW is 1974 also.
Old Sep 30, 2007 | 12:49 PM
Duke94's Avatar
Duke94
Source: "Catalog of Corvette ID numbers"
Old Sep 30, 2007 | 12:56 PM
435/427BB's Avatar
435/427BB
Thanks for all the help!
To Help ID a Rearend
