Frank, it may not be worth your time to rebuild it. Call Ararat (in Scarborough), they rebuild starters and alternaters only. Workmanship is good and you get a warranty. They will use your original parts (if that's important) and the price is around $50.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Its not too hard to rebuild these alternators. The hardest part is be sure you pay attention to the screws with the plastic insulators in them. They have to go back in the same points when you are putting them back in.
Stock
With upgraded diode bridge, rectifier. I also upgraded the field windings but apparently did not take a picture of it.
Very easy to do just did mine about 2 weeks ago. If you have a NAPA auto parts near you they have everything you will need and its cheap. It comes as a kit and even has the pins to hold the brushes out of the way while you put it back together.
Have you considered swapping to a CS-144 instead of rebuilding your old alternator. I recommend it; unless you're trying to stay original.
Thanks for the link, I'd like to stay with what I have, but maybe increase the amps.
At the moment I have 2 1/2 alternators and want to rebuld them so I have 3 completely rebuit ones. I'd rather learn how to rebuild them so that I can do all 3. Thanks for the info Aamir.
Stock
Thanks Eddie, I'm going to use your pictures as a reference. What is the advantage in upgrading the diode bridge, rectifier and field windings?
Are they a stocking Item Richard and do you have an idea on the pricing? Did it also come with the bearings?
