New Suspension Project !
........Sei di Sorrento ?...... Are you from Sorrento ????[/QUOTE]
si (yes)
(ma vivo in spagna da ben 3 anni.!!
If you like to speek about Corvette In Italian..... try to visit the Forum of our Club (Scuderia Corvette Italia):
www.forumcorvette.com
My nick is Stroker, there!
....and this is the "insane" way to have a fun......... we like!
http://it.youtube.com/watch?v=t78rhL1j0Xo
... a couple of times per year we rent a racetrack!
i wish i lived in Italy, i wouldnt miss any of your meetings
Ever think of placing the front arms more inward to provide clearance for wider tires that some will use.
A thought on the price maybe if it all works out ?
As you know when you first time build something the costs are not detectables!
After everything is alltogether and working proprely..... then you can check the costs..... for doing one more time without errors!
The chassis pocket is much larger that the front bracket..... so I'm planning to shim outwards in order to acquire some more clearance!
Unfortunally it's impossible to realize "offset" rods.....
Actually the total lenght (center to center) of the trailing arm is a little mora that 17"...... so the rim is nearly in the mid point of the arm!
Due to this fact you calculate that the widest zone of the wheel is nearly a 12-13" from the hub-center.... and the offset designed in the front bracket is enough!
Of course, if you like, you can place the rodends inside the hub, but I think is not mandatory unless you don't use very wide wheels and tires!
a member of our Club have an important Postproduction Studio in Italy...... so, to easy for us!
If, one day, you will come to Italy..... make me a call!!!!
Two years a go we proudly hosted two guys from the "Corvette Enthusiast" magazine.... Jeffrey Conger ad T.J.
Basically the design is centered in a zero-steer configuration!
In fact the dimension of the toe control rod is nominally neutral..... and, if you see, the angle is the same.
I have built-in some adjustement because you must be able to compensate the variation in camber you may like......
You have two options:
1) you can change the camber adjusting the lower rod and the toe-rod.
2) you can change the camber edjusting the lower and the upper rod.
There is even the possibility to adjust the wheel-hop during hard braking.... changing the relative position between the trailing-rods.
Unfortunely, as you may know, with an IRS rear susension, there is no way to build in lots of antisquat..... because the torque reaction is confined in the differential.
The only way to do it, is to soften the rubber front mount of the differential and to place e link between the plate clamping the leaf spring and the rear cross member...... but the total antisquat can't be more than 25-30%
With Live Axles the antisquat can be even over 100%...... raising the back of the car under hard acceleration.
Anyway I don't care to much this limitation..... because the suspension is basically designed for handlig!
