Brakes pulling
Old Sep 30, 2007 | 05:46 PM
tankman's Avatar
tankman
Default Brakes pulling
Hello Everyone,
All of a sudden friday,my brakes started "pulling" to the right.What should I start looking at to resolve this problem? Thank you all in advance.
tankman
Old Sep 30, 2007 | 06:51 PM
Duke94's Avatar
Duke94
Look for bad rubber hose to front brake. Restricted due to age. Also, sticking caliper pistons due to rust in the bore. What year? (would help if you filled out your profile so we know what you have).
Old Sep 30, 2007 | 07:19 PM
XLAR8R's Avatar
XLAR8R
Just went thru that. FYI Zip sells each individual line it you don't want to buy them all.
Old Sep 30, 2007 | 07:29 PM
tankman's Avatar
tankman
Thank you very much.This happened with my '78 'vette.
Old Sep 30, 2007 | 08:45 PM
Glassbowtie77's Avatar
Glassbowtie77
If your brake hoses are all original I would change them all at the same time and re-bleed the brakes.
Old Sep 30, 2007 | 08:58 PM
tankman's Avatar
tankman
Thank you.
Old Sep 30, 2007 | 11:36 PM
Rdavis's Avatar
Rdavis
Also check to see if you have a leaking caliper. The pads will get soaked with brake fluid. Just got through dealing with that. My right front caliper was leaking & when I hit the brakes it would pull to the left.
Old Oct 1, 2007 | 03:35 AM
tankman's Avatar
tankman
Thank you.I will check out all of the suggestions you guys have offered.
Old Oct 1, 2007 | 04:56 PM
BB68Vett's Avatar
BB68Vett
Just a thought and you should check the obvious brake stuff first, but I had a severe brake pull to the left and it turned out to be the left front inner bearing race spinning in the hub. I bought another hub and that fixed the problem.
Old Oct 1, 2007 | 05:17 PM
another-user's Avatar
another-user
im having the same problem with it pulling to the right.
i had this problem show up last year right before i put the car away, but never got a chance to get to it.
this summer when i got the car back out, the problem was gone. now after about 150 miles of useage, the problem just showed up again.
Old Oct 1, 2007 | 07:36 PM
tankman's Avatar
tankman
I haven't found the time to get started yet,but I sure hope it's not a bearing race.I wouldn't know where to begin fixing it.Thanks to both of you guys for responding.
Old Oct 2, 2007 | 09:57 AM
GruntyPants's Avatar
GruntyPants
Default Suspension...
Also take a look at your front suspension. Check to see if you are missing any shims from the A arm shaft. A buddy of mine had one fall out and during braking the whole arm would shift and cause it to pull.
To Brakes pulling
