I have a 79' with a small block and have been running the monospring composite front end and loving it.
I'm ready to replace my rear spring but am unsure if I should go with a 330 or a 360lb composite spring.
360 is likely what you want. The rear of a 79 with all that glass is a little heavier. I have the 360, and sometimes wondered if I should have gone even more. But thats just me
360 min. You can ask for what they call a heavy 360 spring that may go up as high as 390. But I feel you should be happy with the 360 unless you drag race the car. Then you may wish to go a bit heavier.
Thanks for the replies!
There is a 420lb available as well. What would the 420 do to the ride? I plan to run it out to Bandimere on occasion, but will mostly be driving it around town.
Go 360. I went 330 on VB&P recommendation and the car bottoms out at times. 330 is too soft ----
And don't get the KYB shocks --- they are junk and I don't know why they even sell them. Go Bilsteins if you can afford to --- and if not, then go with a standard GM Delco gas shock---- they are cheap and much better than the KYB's ---- but if you want KYB's I've got a full set of 4 with about 500 miles on them that I will sell CHEAP
I put the # 330 on based on my forum survey. My vett was bottoming out. ( pipes hitting ) so I called VBP and exchanged them for the #360 and am happy with them. Also wounder if the next one up would be better??? I put the Bilstiens on.
Gee, I feel like somebody needs to put in the "good word" for the 330. As a good CRUISING spring it's pretty tough to beat.
I can't say as I've ever "Bottomed" out the exhaust and I'm running my car pretty low. I' also using the front mono spring so it's down there.
Anyway, since I've never used the stiffer spring rates I can't say with any authority that they are too stiff but I can say the 330 and front mono spring combined get the job done without slamming your kidneys over every road imperfection. I love the ride of the car now. At LEGAL speeds I can't imagine needing any more stiffness. Then again the only time my car has ever seen 100 mph is at the end of the 1/4 mile and it hasn't done that in many years.
Gotta agree with who-ever it was that went so negative on the KYBs though.
Despite VBPs assertion that they've been "specially valved" they just can't keep up with the faster reacting fiberglass. Using 'em felt like having no shocks at all the ride was so bouncy. I kept them on the car for all of 2 weeks and then they found their way into the trash can.
Lesson learned and the old saw is still true. Seems like a bargain too good to be true?..........it probably is and it was,........
1980 with a TRW 355# spring and Bilstein Sports. I do not go to the track and have to say that this setup is far from being what anyone would describe as "too stiff". It is a plush setup that works great for cruising. It would be a little soft for serious drag racing.
Thanks for everyone for thowing in. Overall, great information.
I'm currently running QA1 shocks and hoping not to change. I'm thinking 360, any thoughts?
I'm using Bilsteins and recently switched from a 340 spring to a 380 spring for the rear and also last week installed the transverse front spring. I really didn't feel any difference going from 340 to 380 and I xcross and drag. The ride is firm but very comfortable with no body roll, I thnk you can go to a 380 also, call VB&P, they have alot of custom springs you can choose from....
