A new Starter for my '75 ????
Old Oct 5, 2007 | 02:28 AM
10sec75's Avatar
10sec75
Default A new Starter for my '75 ????
My car seems to be eating starters. I just replaced one with a standard rebuilt from Checker, and the problem is starting again.
It starts up perfectly when cold. When warm, it acts as if battery power is low. Clicking and barely turning over.
I have good voltage at the alt, the batt, and the starter.
I'm running a 383 stroker w/Sanderson block huggers and 2.5" exhaust.
I fabbed a little heat shield between the starter and the headers.
I've read a few posts about the stock starter solenoids having a different spring because of heat issues.
I've also read that turning the spring around in a rebuilt can help.
One post recommends only genuine GM.
Any thoughts or experiences??
Old Oct 5, 2007 | 07:09 AM
Durango_Boy's Avatar
Durango_Boy
Lots of guys have swapped to this GM mini starter from later model applications. Direct bolt in and no more heat soaked solenoid problems.
Old Oct 5, 2007 | 08:46 AM
Jims79's Avatar
Jims79
DB is right go w/the GM mini.......no more hot start problems for me.
Old Oct 5, 2007 | 10:23 AM
chuck d's Avatar
chuck d
I had the same problem with my header equipped car. Installed a heat shield, new starter etc. Replaced the battery with one with some "nuts" and it has been good ever since.
Old Oct 5, 2007 | 11:07 AM
PETKAH's Avatar
PETKAH
Had the same problem with my '75. I replaced the battery with a
Interstate that had more cranking and storage amps - thus, it didn't
take long to start = wear and tear on starter. About $85.
Old Oct 5, 2007 | 12:28 PM
10sec75's Avatar
10sec75
If I go with the mini, should it be GM only?
I see alot of after market stuff that claim more torque with less draw on the batt. Any good ones?
I look at the pic of the mini and I wonder if the position of the solinoid will clear my block huggers.
Old Oct 5, 2007 | 12:39 PM
Durango_Boy
The off brand mini starters will probably work but I've heard the best things about the GM starters and I believe they are worth the extra money.
I am not sure of the rotation, so you would want to check out your clearances before ordering.
Old Oct 5, 2007 | 05:06 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I used the GM mini starter that looks like a shrunken version of the stock starter. Works great.
Old Oct 5, 2007 | 05:33 PM
Durango_Boy
Part number? What did it come stock on?
Old Oct 5, 2007 | 06:32 PM
10sec75's Avatar
10sec75
I'm going with the mini GM and wrap it real well. Sounds like that's the ticket!!
Old Oct 5, 2007 | 08:12 PM
jcswm's Avatar
jcswm
1st retard the timing a few degrees and see if your starting problem goes away
if you still have a problem buy a mini-starter
late 90's suburban/silverado starters bolt right up
Old Oct 5, 2007 | 08:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
No clue...bought it at AutoZone, listed in the cross-references for all 350s.
Old Oct 5, 2007 | 09:30 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I purchased this MSD mini starter from Summit Racing and have had zero problems....
Old Oct 6, 2007 | 12:45 AM
10sec75's Avatar
10sec75
My initial timing is set at 12. I have tried pulling it back but it doesn't help the issue.
Everybody read great the sticky from BarryK ??? Gonna do it this week!!
To A new Starter for my '75 ????
