Tonights Adventure...Grrrr
Old Oct 5, 2007 | 06:05 PM
SIXFOOTER's Avatar
SIXFOOTER
Default Tonights Adventure...Grrrr
OK, so tonight is Break In the Cam night. Fired up great, runs strong. Headers heat up Bright red in about 3 minutes and burn the hell out of 3 plug wires, I shut it down when I got flames.
Should they get that hot that fast?
I got ceramic coated block huggers, base L81 with mild cam, stock carb on a RPM intake and stock ignition
I did not expect that kind of heat
So now what to do about my plug wires??
HELP!!
Old Oct 5, 2007 | 06:16 PM
Durango_Boy's Avatar
Durango_Boy
I would think that's too hot. Maybe advanced a bit?
Oh, yeah, um...replace the plug wires that burned.
Old Oct 5, 2007 | 06:27 PM
Jclgodale3's Avatar
Jclgodale3
That is "not" unusual for the header tubes to get that hot on a fresh motor. That is why it is suggested, if you have new chrome headers, to use something old for exhaust during break in. (to keep from discoloring the new chrome) Oh...and yeah...replace the burnt wires, restart and then check your timing
Old Oct 5, 2007 | 06:41 PM
mrvette's Avatar
mrvette
Situation normal.....I remember my stock L48 with the TPI on it, and ram's horns, the O2 sensor in the heat riser flapper position....
well one evening/night after a good hard run, I opened the hood in darkness....and the manifolds were glowing orange to yellow, really super hot...well yes, after a good run, HELL yes....easy to turn a piece of steel yellow with a propane torch that engine exhaust can do it to a set of headers in a flash....literally....
what made me pop the hood, was the gray looking appearance of the centers of the ram's horns, the part not fastened to the engine....the runners from the end cylinders....all 4 corner tubes were gray and somewhat stressed looking, but not cracked....looking kinds like they could crack though....3 years later they were still fine.....but you see, a TPI system, or any closed loop runs far leaner than most typical carb setups.....see posts from Norval/Strider about that topic.....
OH, and yes, replace the re do the wire routing....
and welcome to the headers burning wires and plug ends club....
Old Oct 5, 2007 | 06:42 PM
Older Than Dirt's Avatar
Older Than Dirt
Here's what Jet Hot Rust recommends..
Old Oct 5, 2007 | 06:47 PM
Z-man's Avatar
Z-man
Not that unusual. If the headers are new, I wouldn't use them until you've got it fully broken in. That way you can gently break in the headers. Well, maybe it's too late..
Even after the engine is broken in and driven for a while, it's not unusual to see the headers glow a slight pink/faint red especially at night when you can see it. I think the low level red color starts at about 800*F.
Old Oct 5, 2007 | 08:47 PM
Durango_Boy
So, I'm curious...what is it about a fresh motor being broken in that makes it normal to be that hot?
Old Oct 5, 2007 | 09:04 PM
desi's Avatar
desi
running for 20+ minutes at 2000 - 3,000 rpm.
Old Oct 5, 2007 | 10:03 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Oct 5, 2007 | 10:05 PM
Durango_Boy
I used to do that on the way out to a softball game on the highway, at 3500, for about fifteen - twenty minutes. Usually popped my hood to help let out the heat but the headers were never red, even in the failing light of the evening.
Old Oct 5, 2007 | 10:25 PM
Jclgodale3's Avatar
Jclgodale3
Were you breaking in a fresh (newly built) motor each time?
Old Oct 6, 2007 | 12:26 AM
SIXFOOTER's Avatar
SIXFOOTER
I think the fuel mix was way off, fried my headers, 2 plug boots and 1 wire. I didn't realize that it would get that hot, was concerened about getting break in done and not the dial in. That won't happen again, $200 mistake!
So, got to order new headers and plug wire set, will go ahead and dial in the carb and valves and then finish breakin
dammit
Old Oct 6, 2007 | 12:35 AM
Frank_833's Avatar
Frank_833
Don't forget a FAN to blow air across the engine while doing a cam brake-in!!!!
Old Oct 6, 2007 | 12:40 AM
1980 blue L48's Avatar
1980 blue L48
Retarded spark timming makes for hot exhaust temps. Ignition needs advanced, to late now.
Old Oct 6, 2007 | 01:30 AM
10sec75's Avatar
10sec75
A real good trick on break in is to use an infrared temp gauge and shoot the exhaust while your running.
At a constant between 1500 and 2000 rpm, the temp should not exceed around 1000*.
If it approches this temp, advance the timing just a bit while the car is still running.
It just takes a few seconds to see the temp retreat if the timing was too retarded.
If my new headers approached 1000*, I would want to know it.
Old Oct 6, 2007 | 07:47 AM
mrvette's Avatar
mrvette
LOok at them in pitch dark....totally black after a good run...quickly pop the hood, and see them....orange to yellow glo fading fast in steel tubes, takes longer with iron rams horns....and with leaner TPI or any DPFI for that matter running closed loop, it's running hotter yet....
course if you have a set of spals on running, they MAY cool the things down faster than you can get out...but not the iron...that takes a while....
Old Oct 6, 2007 | 08:16 AM
Durango_Boy
Three or four times yes, once or twice is was just heads, cam, lifter, or all three.
To Tonights Adventure...Grrrr
Old Oct 6, 2007 | 06:51 PM
Jclgodale3's Avatar
Jclgodale3
anyway...as said before, it's not unusual
Old Oct 6, 2007 | 06:52 PM
Jclgodale3's Avatar
Jclgodale3
All three + new bearings rings, pump, timing chain etc=a freshly built motor in my book. 1 item=just an upgrade...
Old Oct 6, 2007 | 07:35 PM
Durango_Boy
I believe that, I'm just wondering why the extra heat is common with a fresh build. Is it the extra friction from rings that have not seated and things like that?
