Radiator Temperature Chart
Old Oct 6, 2007 | 11:09 AM
Durango_Boy's Avatar
Durango_Boy
Default Radiator Temperature Chart
I am trying to locate the best position for an electric fan. Obviously where the hot coolant enters the radiator will be the hottest, but considering the flow of the coolant down to the return hose, which areas are the hottest and would benefit most from having electric fan driven air flow?
Using the chart below, and a scale of 1-8, which sectors are the hottest?
Old Oct 6, 2007 | 01:03 PM
SIXFOOTER's Avatar
SIXFOOTER
There might be a measureable difference, but practically speaking I can't see it mattering much. I would stick it in the center or for best fit for easy install and call it good
Old Oct 6, 2007 | 01:09 PM
greg454's Avatar
greg454
Because its a cross flow it would be hottest left to right. 1&5 hottest and 4 & 8 coolest. Not a whole lot of difference top to bottom.
Old Oct 6, 2007 | 02:09 PM
mrvette's Avatar
mrvette
MY advice.....mount that fan with about a 2" space from the shroud to the rad core, and fill in around it so the plenum created by fan shroud and COMPLETE RAD CORE is covered 100% tightly.....I bent aluminum flashing, and some thicker aluminum parts/L angles from HD/Lowes to extend from rad mounts brackets...side to side, tie the fan to that, and then from fan shroud with the aluminum....I did it all in an afternoon on the driveway one Saturday....took the whole thing except the a/c grill outta there, for ease of assy.....if I can do it with Spals, you can do it with a single fan.....mucho easier than it looks....
Old Oct 6, 2007 | 02:43 PM
Durango_Boy
Yeah, I was just gong to center it, but I have a little room to work with, and my transmission cooler fan is on the driver's side. I can either go middle, passenger side, or overlap the transmission cooler fan.
I was just thinking I may get an advantage if I position the fan to pull air through the hottest part of the radiator.
Old Oct 6, 2007 | 04:04 PM
noonie's Avatar
noonie
That's the correct way. Make a complete sealed plenum.
If it's the Mark fan, then perhaps you can mount it in the original GM shroud by cutting and reglassing.
BTW
Somewhere I have the test results of aluminum and copper rads broken into quandrants like that and the single row aluminum rads show very little differnce in the quads whereas the copper ones showed the centers and being coolest.
Old Oct 6, 2007 | 06:37 PM
carriljc's Avatar
carriljc
Default Depending on what year Corvette you have...
you might be able to cover the whole dang radiator. I installed a Summit Radiator, ~28" by ~19', and my Mark VIII fan fit perfectly over the core.....if it had been my original radiator it would have covered even more.
Some pics of original installation below: (I've cleaned it up some since then)
http://forums.corvetteforum.com/show...=mark+viii+fan
Old Oct 6, 2007 | 06:55 PM
S489's Avatar
S489
hottest areas identified above. technically, the area where forced air flow is most effective is the hottest area of the radiator. that is where the temperature difference between the air and radiator is the greatest, and the cooling effect greater.
practically, installing a good shroud should do more than fan location. i like the shrouds that have flaps that open when cruising.
Old Oct 7, 2007 | 02:22 AM
Jclgodale3's Avatar
Jclgodale3
Last edited by Jclgodale3; Oct 7, 2007 at 10:45 AM. Reason: op didn't want pictureas
Old Oct 7, 2007 | 08:43 AM
Durango_Boy
I already have those pics, but thanks anyway.
To Radiator Temperature Chart
