Map Pocket Removal?
Old Oct 6, 2007 | 10:48 PM
VettePower's Avatar
VettePower
Default Map Pocket Removal?
How do I remove the map pocket panel on a 77??
Old Oct 6, 2007 | 11:02 PM
Durango_Boy's Avatar
Durango_Boy
You have to remove the knee pad, and disconnect the springs that hold it in place.
Or...just pull VERY hard.
Old Oct 6, 2007 | 11:17 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The whole dash pad? Take off the dash pad screws and the two facing the door panel, it should just fall out to the right.
Old Oct 6, 2007 | 11:23 PM
VettePower's Avatar
VettePower
DB - Say what? What is a knee pad?? Are you saying I can just pull on it (hard) and it will come off??
Old Oct 7, 2007 | 12:25 AM
Jclgodale3's Avatar
Jclgodale3
Don't do that
Old Oct 7, 2007 | 02:34 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think he was just talking about the pocket - if you pull on it hard enough the springs will break. I messed one of mine up a while back. There are only a handful of screws holding that whole panel up, it won't take long to get them out. Three across the top, two in the door opening and one by the center cluster.
Old Oct 7, 2007 | 08:41 AM
Durango_Boy
Yep, he nailed it. I totally missed that you meant those whole panel and thought you meant the map pocket alone. My bad.
Old Oct 7, 2007 | 10:38 AM
Jclgodale3's Avatar
Jclgodale3
Better idea and less destructive
Old Oct 7, 2007 | 03:53 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It can be kind of destructive when the panel falls down, spins out of the door opening and bounces on the concrete...
Old Oct 7, 2007 | 08:57 PM
VettePower's Avatar
VettePower
I did just mean the map pocket panel. Is everyone saying I have to take off the whole dash pad to get the map pocket panel off????
Old Oct 7, 2007 | 09:43 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Pretty much, unless you have a small, triple-jointed arm. Taking the whole panel down is easy.
Old Oct 7, 2007 | 10:01 PM
VettePower's Avatar
VettePower
No way is my arm like that any more!!! Thanks Batman!!!
Keep Gotham safe, my friend!!
To Map Pocket Removal?
