zz4 turnkey in 80
Old Oct 10, 2007 | 06:12 AM
kanngaroo jack's Avatar
kanngaroo jack
Default zz4 turnkey in 80
thinking of puting a turn key zz4 in my 80 vette , any thing i should know eg" clearances, are they reveres flow , do i need electric fans, serpentine belt system, will it bolt up to my trans auto . Thanks to anyone that can help
Old Oct 10, 2007 | 09:07 AM
Binnie77's Avatar
Binnie77
I did this with my '77. I have the process documented at
http://corvettec3.ca/zz4.htm
I think you will be pleased with the results.
Old Oct 10, 2007 | 09:51 AM
Bob Onit's Avatar
Bob Onit
Just installed one in my '73. You will need the short water pump.
The exhaust ports on the heads are a D shaped port that may may require a little porting on stock exhaust manifolds. Existing headers should work ok.
If your temp sending unit is located in the drivers side cylinder head it will have to be re located to the intake manifold.
Most ZZ4's I've seen come with a 14" flex plate so you should be ok.
Good little engine with tons of torque.
Old Oct 10, 2007 | 10:05 AM
Ken74Conv's Avatar
Ken74Conv
Binnie77
Where did you get the ZZ4 hood emblem?
Thanks,
Old Oct 11, 2007 | 08:33 AM
Binnie77's Avatar
Binnie77
Originally Posted by Ken74Conv
Binnie77
Thanks,
I got them on an ebay store. This is the link.
http://stores.ebay.com/FlipsGraphXdeSign
If you do not see them, just drop him a message and describe what you are looking for.
To zz4 turnkey in 80
