Trailing Arm Studs
Old Oct 10, 2007 | 02:39 PM
stinger12's Avatar
stinger12
Default Trailing Arm Studs
I installed new trailing arm studs in both of my trailing arms yesterday. I am referring to the studs which secure the bearing support/attaching parts to the trailing arm. I realized that 3 of the four studs on one trailing arm could be wiggled with my hand just a tiny bit, yet when I bolted the bearing support to them, they held together and didn't spin in the hole. Should I just place a tiny bit of loctite red on the base of the studs when I install them just to prevent the wiggling?
Old Oct 10, 2007 | 02:41 PM
stinger12's Avatar
stinger12
Basically, they did their job but I would just like to prevent the wiggling. They are tvery secure after everything has been bolted down...so I don't think it is a huge issue.
Old Oct 10, 2007 | 04:10 PM
stinger12's Avatar
stinger12
bump
Old Oct 10, 2007 | 06:05 PM
stinger12's Avatar
stinger12
bump
Old Oct 10, 2007 | 06:18 PM
jyounane's Avatar
jyounane
Not a problem. They are pressed in to make assembly convenient....no structural significance. You could use regular bolts and they'd do the same job.
Joe
Old Oct 11, 2007 | 01:03 AM
stinger12's Avatar
stinger12
Thanks for the reply jyounane, much appreciated. I'm relieved that it doesn't matter...I thought I was going to have to start modifying stuff!
To Trailing Arm Studs
