Electric Water Pump?
The EWP pump the same flow at idle than at WOT...... this is not a good thing.
Think about this case: you floor it and go WOT with a stock water pump, you hit 150 mph (
) then decide to slow back down when you hit a traffic jam. When the engine was WOT the water pump was pumping fast for only a few seconds. Now when you slow back down, the heat begins to build up but the water pump isn't pumping fast anymore. If you had an electric, it would still be pumping rapidly - even if the car was sitting at idle.Over here, in the Summer, cooling Vette engines while in traffic is a bigger problem than cooling the engines while moving on the highway - at least that is what most people complain about.
) then decide to slow back down when you hit a traffic jam. When the engine was WOT the water pump was pumping fast for only a few seconds. Now when you slow back down, the heat begins to build up but the water pump isn't pumping fast anymore. If you had an electric, it would still be pumping rapidly - even if the car was sitting at idle.OK..... I guess that a clever man must be able to change idea...... but not so much!!!!
I have to agree with you in the case you sed..... but (there is ALLWAYS a "but".....) for the "energy" theme I stay with me!!!
If you need 0.3 Hp to move the water you need..... at least, you will drag the same power in both cases.
Moreover you have to consider that the efficency of the alternator is in the range of 85-90%...... so, with an electric water pump, you will drag 10-15% more power from the engine.
...... unless you like to discharge your battery!
My point? It's harder to kill mechanical pumps, than electric ones. They're also USUALLY cheaper. (If you're running a carb the mech. fuel pumps are dirt cheap as are water pumps.) Nuff said?
It's been I long time since I've been anywhere close to overheating now that the temperatures have cooled down, but sitting at a light is when my water temp reaches it's max and I'm using an electric markVIII fan.Out of curiousity, does would a 70amp alternator pull the same or less out of the motor that say a.... 130 amp? I need to upgrade mine to handle that fan as well as the multiport fuel injection of my inprogress motor and possibly an electric water pump.
