Getting .001-.002 Endplay On Trailing Arm
Old Oct 12, 2007 | 03:33 PM
stinger12's Avatar
stinger12
Default Getting .001-.002 Endplay On Trailing Arm
Could I just take a piece of glass (glass is flat) and tape a piece of wet/dry sandpaper to it. Then take the shim and apply even pressure to it, slowly drag it across the sandpaper and then check the endplay again. Basically repeat the process until my endplay is between .001-.002? The shim will originally be just a bit larger than what I need. Unfortunatly I don't have access to a parallel grinder. Thanks
Old Oct 12, 2007 | 03:53 PM
Scott Marzahl's Avatar
Scott Marzahl
Crocus cloth works better than regular wet and dry and mineral spirits is a good solvent. Use a figure 8 pattern for more even results. This is a very common process to do and is often referred to as "dressing" a thrust washer or in this case a shim. You can use this method to dial in the front wheel bearings as well as the rear ones you are working on. Any more than two or three thous should be ground to ensure parallel surfaces.
Old Oct 12, 2007 | 04:08 PM
stinger12's Avatar
stinger12
What is crocus cloth and where can i get it?
Old Oct 12, 2007 | 04:23 PM
Scott Marzahl
Almost any good auto parts like a NAPA or hardware store.
Old Oct 12, 2007 | 05:32 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
That's exactly what I did. I used 320 wet/dry paper with PB Blaster on a 1/4" sheet of tempered glass. .001 on both sides
Old Oct 12, 2007 | 07:51 PM
Artsvette73's Avatar
Artsvette73
Works very well
Old Oct 13, 2007 | 01:05 AM
stinger12's Avatar
stinger12
sweet, looks like I have it all figured out then! Thanks guys.
Old Oct 13, 2007 | 07:48 AM
78anniversary's Avatar
78anniversary
The biggest reason a parallel grinder is used is to keep both sides of the shims and spacers parallel with each other. Sanding on a piece of glass will true the one surface but will not quarantee that it is parallel with the opposite end.
To Getting .001-.002 Endplay On Trailing Arm
