Since no one else has chimmed in, here is some help in a nutshell.
It's rather a very straightforward and intuitive job. Perhaps a Haynes manual would cover it for you. You'll need to buy or rent a Pitman arm puller to first remove the large pitman arm from the box. Pullers come in various sizes so measure the width of your pitman arm before going to Autozone etc to rent the tool to make sure you get the right size the first time. This is the biggest PITA since they can really be stuck on the box really good. An impact wrench comes in handy on the puller here. (You may have to remove the arm from the steering linkage first, I don't remember off the top of my head, in which case you'll need another type of seperator). They you can loosen up the steering coupler between the column and the box noting the orientation of the coupler to the box. The box is held to the frame by three bolts, unscrew the three nuts on the box side. You may need to pry the coupler open a little bit in order to slide the box free.
Does anyone know what size wench I need for the pitman arm to steering box nut. Also, do I need to remove the pitman arm from the steering valve before I remove the pitman arm from the steering box?
1-5/16" socket for the pitman arm nut. Be sure to do this with the box in the car to hold it in place, have the wheels straight and loaded.
Use a 2 jaw tie rod puller to remove the arm from the CV. If you use a pickle fork it most likely will rip the rubber boot.
Also be very careful when you work on the rag joint. Remove the pinch bolts and mark the steering column so that you don't drive it up into the column. You can do this without knowing it. Then pull the 3 carriage bolts from the frame and the box will come out.
Look at the frame where the box mounts and where the Ram A bracket mounts to the frame. This areas will sometimes rip. Reinforment plates can be made to weld in if you want or need to fix.
I have been trying to find a 2 Jaw Tie rod puller. Does anyone have a source or part number. I went to the local Harbor Freight store and they said theirs was discontinued.
Sears has several Craftsman 2 jaw pullers you can buy for around 50.00, if your only going to use it the one time try Autozone and rent like they said above
