3.90 vs 4.10
Old 10-13-2007, 04:04 PM
Jayson77
Jayson77's Avatar
Default 3.90 vs 4.10
I have 3.55s in my differential right now. Im thinking of bumping to 3.90s or 4.10s. How much of a bottom end difference is the jump? I dont think I'll be able to tell a difference if I go with 3.70s.
Old 10-13-2007, 04:09 PM
toddalin
toddalin's Avatar
Received 1,196 Likes on 491 Posts
Are you going aftermarket? Neither 3.90s nor 4.10s are GM Corvette gears. GM Corvette gears jump from 3.70s to 4.11s.
Old 10-13-2007, 04:12 PM
Jayson77
Jayson77's Avatar
I am going aftermarket. Not a lot of companys make 3.90s but I figured it would be more streetable than 4.10/ 4.11. Not really sure about it so thats why I asked.
Old 10-13-2007, 04:15 PM
Belgian1979vette
Belgian1979vette's Avatar
Concerning streetable there is not much difference in the two gears
Old 10-13-2007, 04:18 PM
Jayson77
Jayson77's Avatar
Im just wondering how much of a bottom end difference there is from 3.55s to 3.90 or 4.10/ 4.11 from someone how has the setup.
Old 10-13-2007, 04:19 PM
panic
panic's Avatar
4.11 gears has no merci for both your wallet and your competitors (if you have a proper engine to back it up and you want an extra push on sprintings)
Old 10-13-2007, 04:21 PM
Jayson77
Jayson77's Avatar
Do you think I would tell much difference if I went to 3.70s
Old 10-13-2007, 04:24 PM
Belgian1979vette
Do you have 4.11's panic ?
Roughrider
Roughrider's Avatar
My '69 427/435 has factory 4.11 gears (and an L88 cam)...I call the car "Stumpy" because it could pull tree stumps. It really doesn't even need 1st and 2nd gears.
If you like turning lots of rpm's at moderate speeds and single-digit fuel mileage, go for it. I get maybe 6mpg and about 125 miles to a tank of gas.
Old 10-13-2007, 04:29 PM
panic
panic's Avatar
Old 10-13-2007, 04:31 PM
panic
panic's Avatar
I'd say if you want to drain your wallet it's useless to leave a few coins in...go for the 4.11
Old 10-13-2007, 04:32 PM
Ironcross
Ironcross's Avatar
If you have a good motor, it`s the icing on the cake. .....
putting it another way, thats why Corvettes were built.
Old 10-13-2007, 04:38 PM
Jayson77
Jayson77's Avatar
Thanks good point
Old 10-13-2007, 05:40 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Dont..If you really want acceleration get the 4.10. Anything over a 3.40 gear and your crusing rpm will climb up there anyway, so go for the gusto.
If you dont have one, get a 700R too, and have the best of both worlds.
I went from 3.08 to 3.73 to "split the difference" (this was in another car I have)..Bad move.
A week later I was in the shop getting 4.11s and did an overdrive conversion, best thing I ever did.
Old 10-13-2007, 06:18 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
Sent PM!
Old 10-13-2007, 06:45 PM
fastrthnu
fastrthnu's Avatar
actually thats wrong...GM offered a 3:90 over the counter...#3970551
Old 10-13-2007, 06:47 PM
Jayson77
Jayson77's Avatar
A week later I was in the shop getting 4.11s and did an overdrive conversion, best thing I ever did.[/QUOTE]
Ive repurchased many different parts because I didnt like the way they've performed like radiators, water pumps, fans, intakes, carbs,heads, ect. the list goes on and on. Sometime down the road I'll be looking at a 2004r con. So why not 4.11s, thanks
To 3.90 vs 4.10
Old 10-13-2007, 06:49 PM
Jayson77
Jayson77's Avatar
Are they 63-79 corvette?
Old 10-13-2007, 07:28 PM
toddalin
toddalin's Avatar
I changed my 4.11s to 3.70s. 4.11s are fun, but without an OD, you'll turn about 3,600-3,800 RPM in the slow lane just trying to keep up with the ricers on the freeway. 3.70s reduced this to about 3,200-3,400 RPM.
I found that 3,800 RPM = lots of vibration, noise, and lousy gas mileage.
Eventually I put a TKO-600 in so, the 4.11s would have been OK. But consider that compared to the Muncie, 1st on the TKO is equivelent to going to a ~3.90 rear gear in 1st.
Old 10-13-2007, 08:11 PM
fastrthnu
fastrthnu's Avatar
they were...it`s doubtful any C-3 ring and pinions are still available from GM.
Quick Reply: 3.90 vs 4.10
