Need A Beffier Irs Differential
Old Oct 13, 2007 | 10:32 PM
captainamerica's Avatar
captainamerica
1st Gear
Default Need A Beffier Irs Differential
Does anyone know of anyone who makes a stronger differential for the C3 IRS?
Old Oct 13, 2007 | 10:43 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Tom's Differentials. Pretty much the main folks messing with them.
Lots of 8 and 9 sec Vette's with them.
JIM
Old Oct 14, 2007 | 12:50 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Mine isn't from Tom's, but I can attest that an Eaton based 12-bolt IRS diff conversion is the way to go. I'd upgrade your half-shafts at least to factory 3" pieces, and make sure to run solid Spicer U's, too.
Old Oct 14, 2007 | 12:53 AM
69ttop502's Avatar
69ttop502
Van Steel now carries the Tom's pieces as well. I got my 30 spline inner/outer axles and 1480 series U-joint Half shafts from them.
Old Oct 14, 2007 | 04:30 AM
ltlevil's Avatar
ltlevil
Charlie can you give a little more info on who did your rearend?
Thanks,
ltlevil
Old Oct 14, 2007 | 12:52 PM
TheSkunkWorks
Thanks,
ltlevil
My first one was done by a local shop (long since gone) in Memphis using a tight Moroso posi. While it was fine in a straight line, the instability caused by ratcheting when trying to put power down in fast sweepers was undesirable, to say the least. I could probably adjust that out and put it to use on certain courses, but the 4.11:1 proved too deep for the street and I'm not that into parking lot variety auto-Xing.
The one currently in my SA was done by Henry's Machine Works using an Eaton posi and 3.55. I can't recall a name, as it's been about 20 years, but the guy who used to do Muldowney's diffs set it up. I've broken and upgraded other stuff since, but the diff has proved bullet proof. If I ever have to let go of my SA, this piece stays with me.
Old Oct 14, 2007 | 04:44 PM
ltlevil's Avatar
ltlevil
Can't blame you for wanting to keep it. Thanks for the info.
Steve
Old Oct 14, 2007 | 05:18 PM
panic's Avatar
panic
I think van steel's assemblies with tom's parts is the way to go...so you'll have the best of both worlds, best parts (from tom's) and best follow up and support (from van steel).
Just my personal experience.
To Need A Beffier Irs Differential
