OK, so I'm working on a front suspension rebuild and I'm about 3/4 of the way through teardown. I've got the right side off completely. On the left side I've got everything off except the upper A-Arm.
I found the right upper A-Arm wouldn't slide off the end of the bolts because the fan shroud was in the way. So I had to take the bolts out. Which was no fun because the fan shroud was so close.
The left looks to be much more of a pain seeing as there is something in the way (alternator?). Will the left side slide off without removing the bolts? If not should I remove the thing in the way to give myself more access?
I started taking off the nuts and my ratcheting wrench can only get like 2 clicks on the front nut per turn, so obviously it would be easier with more clearance.
Yep, you can either fight the thing for half a day or just go ahead and pull it and get your stuff done. Pulling the bolts out of the frame is not a good idea because they are knurled and pressed into the frame. If you go ahead and pull the shroud you can avoid all that.
