Differential
Doug
Doug
Here is the list of "while I'm at its" when I rebuilt mine on the '70. They are NOT required to do, but if they need attention, now's the time. You can just replace the diff without doing any of this.
Half shaft and drive shaft U-joints replacement...cleaned/painted shafts.
New differential mounting bushing
Cleaned/painted diff crossmember and other mounting brackets.
Grease inner TA bearings
You will also need to remove the strut rods, brakets and rear spring...so if you're thinking about maint/replacement, now may be the time...
Damn, those while I'm at it's mount up.
Our price for a rear end is $1245 and includes a new gear set, bearings, seals, clutch pack, preload kit, stub axles, HD rear cover, drain plug and pinion flange. The shipping is free and there is no core charge. We build our differentials in house and they come with a three year warranty. If you want yours rebuilt, we can do that too.
Compare that to:
Ecklers - New Gear set, bearings, seals, clutch pack a 1 year warranty $899.00 + $450 core charge = $1349 no stub axles, rear cover, preload kit and you pay shipping
Mid America- New bearings, seals, clutch pack used ring and pinion a 1 year warranty $1099.00 + 350 core charge = $1449 no stub axles, rear cover, preload kit and you pay shipping
Van Steel does not post a price on the website that I can find.
We are also a supporting vendor.
Compare that to:
Rick B.
I think providing options and listing prices is a benefit to everyone. The truth is we have a very good deal on differentials and Im trying to save my fellow Corvette owners some money. I would never say anything negative about a competitor, but I will compete.
