Dual mount rear spring.
Old Oct 17, 2007 | 12:41 AM
68L71's Avatar
68L71
Default Dual mount rear spring.
Can a spare tire carrier be run with vb rear dual mount spring?
Old Oct 17, 2007 | 01:02 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Shouldn't be a problem. It's the same width as a stock spring and mounts in the same orientation...it just uses a different mounting method.
Old Oct 17, 2007 | 05:05 AM
WayneLBurnham's Avatar
WayneLBurnham
Default Works on mine!
....now to mount the Holley Black E-Pump above it!
Old Oct 17, 2007 | 09:37 AM
68L71's Avatar
68L71
Default is it worth it?
Ok so it will fit, but is it worth it? I already have a vb composite spring and I am currently updating to the front mono spring. I need to put in new rear wheel bearings and rebuild the differential so I will be into the rear-end anyway.
Old Oct 17, 2007 | 10:33 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
It is worth it if you plan on running a fat tire and wheel combo. 1) because you can't run a rear bar if you go that route. 2) the dual mount compinsates for not running a rear bar b/c the mounting locations are spread out and it will not allow the body to roll as much as a car with a stock spring or standard fiberglass spring. If your not going to fatter tires than stay with a standard fiberglass spring.
Old Oct 17, 2007 | 04:05 PM
Binnie77's Avatar
Binnie77
I just installed the dual mount kit on my '77 and there is lots of room for the spare tire tub. You will not regret going the dual mount route. Just the ability to adjust ride harshness is well worth the extra bucks over the center mount type.
Old Oct 17, 2007 | 06:50 PM
68L71's Avatar
68L71
Thanks all, I ordered one today, taking advantage of vb 30% off sale!
To Dual mount rear spring.
