Blower motor
Old Oct 17, 2007 | 08:29 PM
63_GrandSport's Avatar
63_GrandSport
Default Blower motor
What do I have to do to get it out? Does it come out through the engine bay or under the dash?
Old Oct 17, 2007 | 08:51 PM
Durango_Boy's Avatar
Durango_Boy
Engine bay. It's easier if you start by taking out the puke tank. Then, reach around and under the fender. Remove the wiring, and tube from the fan housing. Then remove the four hex screws that hold the fan to the box.
Clean the surface very well before putting a new one in.
Old Oct 17, 2007 | 08:56 PM
63_GrandSport
Originally Posted by Durango_boy
Engine bay. It's easier if you start by taking out the puke tank. Then, reach around and under the fender. Remove the wiring, and tube from the fan housing. Then remove the four hew screws that hold the fan to the box.
Thanks that helps.
Old Oct 17, 2007 | 08:57 PM
Durango_Boy
Thanks that helps.
Glad to help even just a little bit.
Old Oct 17, 2007 | 09:03 PM
pbcanney's Avatar
pbcanney
Thanks that helps.
ez job.
got my replacement motor off ebay for like $40
Old Oct 17, 2007 | 09:37 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Hard to get it out with the A/C lines in place, though.
Old Oct 18, 2007 | 08:39 PM
63_GrandSport
Originally Posted by pbcanney
ez job.
Ac lines no problem someone cut them before I got it Just somthing else I have to replace
Old Oct 18, 2007 | 10:20 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Certainly makes it easier to get the fan assembly out.
To Blower motor
