77 in dash lighting failure
Old Oct 17, 2007 | 11:26 PM
yoitslikejohn's Avatar
yoitslikejohn
Default 77 in dash lighting failure
I was driving home from work yesterday and I turned on the lights in my 77 and the headlights came up and turned on, but the indash lighting around the speedometer and tach gauges did not turn on. The turn signals still worked fine, but the lights behind the gauges would not turn on. I tried to investigate the problem, but needless to say it is very hard to see up under the dash and would really like to avoid having to drop the steering column and remove it. Suggestions about the possible cause of this problem would be greatly appreciated.
Old Oct 17, 2007 | 11:28 PM
...Roger...'s Avatar
...Roger...
Check the INST light fuse.
Old Oct 17, 2007 | 11:53 PM
yoitslikejohn
Good call, the fuse was blown. Hopefully thats the extent of the issue. Thanks for your help.
Old Oct 18, 2007 | 12:20 AM
Steve COSD's Avatar
Steve COSD
If the fuse keeps blowing in the future replace the headlight switch. Especially if the current one is the original.
Good Luck,
Steve
To 77 in dash lighting failure
