If you are very talented at fabrication and a good welder you could certainly make your own lower arms. If not, you are better off buying them from an established builder. Nothing worse than having your front suspension fall apart while carving your way through the Italian Alps.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The a-arms in the pics look very interesting. I think that would be an improvement over what is in there as stock but, like you say they may be weak for the punishment that could be handed to them. Fabricating your own set is nice if you have the tools and talent. I know I don't have the tools in my garage.
But, did you consider the satisfaction of making parts your own?
I like very much to own a car wich is different from the others..... original !
The Impala option is very interesting.... I gonna check in the web for some shop!
Anyway, to my eyes, the Impala lower arm look a bit weak...... it is?
I'm all for being unique - I haven't seen 2 LS1 conversions yet that are exactly the same. If you have good fabrication skills and knowledge of chassis and steering design you could build yourself a really nice set of control arms. The bottom line is safety - if the end result doesn't handle well or does unpredictable things because the geometry is off you could kill yourself and/or others.
Check out Van Steel's website. They have a coil-over front suspension and just announced a rear coil-over suspension. Costs a few $ but you could have a very unique car that has a proven suspension.
