differential setup question
Old Oct 20, 2007 | 12:55 AM
wes weigle's Avatar
wes weigle
Default differential setup question
I'm setting up a differential and I'm finding that I can get the backlash correct for one of the spider gears at .006,which is within what I believe to be within the factiry specs of .005-.008. The other spider gear I only get .003, which is according to the factory book is to small. If I switch spider gears its is the same .005 at the large opening in the case and .003 at the other side. I am using a new centering pin. Any suggestions or Ideas as to what is wrong. Thanks for your help!
Old Oct 20, 2007 | 02:51 AM
Vesa's Avatar
Vesa
How do you measure it (picture?), hard to understand how one can get diffrent backlash from "same gear" but different side...
