Torsion Damper HELP ! !
. How hard is it to replace the damper, and how long can I drive the car like this without damaging anything? Thanks for any help from the forum.
Stop at a parts store, and get a balancer puller and installer kit. most of them will rent them for free.
Remove the balancer with one kit, and install the new one with the other. Some kits do both.
When installing the new balancer, drip lots of oil on the threads of the installer to help lube and guard against friction built up while installing. Lots of pressure is applied to the threads when cranking it on.
Turn the installer until the balancer seats against the shoulder on the crank...basically all the way on.
Good luck.
