ahhhhhhh!!!!!!!!!
Old Oct 21, 2007 | 01:18 AM
joehalford01's Avatar
joehalford01
Default ahhhhhhh!!!!!!!!!
Whoever said it was time for a frame off when i asked my first question about changing the pads.......what is it about these cars?????
I got the front calipers mounted along with the stainless flex lines- started on the rears- went to install the drivers side stainless flex line and the distribution block snapped at the connection!!!! so i figure ok, i'll get the block off and see if i can get another local.....
the darn main line was so corroded that the fitting stripped in no time...and i used a snap on flare wrench so it wasn't a case of the wrong tools (i don't know how i even got this tool as i've never used it until i started working on these brakes).
if i'm going to replace the hardest brake line to replace, i might as well do them all
so i now i'm waiting for my full stainless brake line kit, all new clips, and new distribution blocks. I was halfway tempted to just order a new proportioning vavle and master cylinder so i wouldn't break those installing everything else .
Old Oct 21, 2007 | 01:33 AM
Durango_Boy's Avatar
Durango_Boy
Sounds rough man. A tip for next time, is clamp the line wrench with a small Vise Grips so it won't slip and strip.
Hope you get it all taken care of.
Old Oct 21, 2007 | 02:56 AM
RunningMan373's Avatar
RunningMan373
If they strip out, you can usually get them loose with a vice grip, It destroys the thread, but works. Reinstall them with one too, if just one, I mean, how many times do you change the brake lines in a car? That's what I did with my D/S ss to rubber flex line. That's a good idea DB, hadn't heard of that before.
Old Oct 21, 2007 | 11:57 AM
joehalford01
i considered that, but i really can't bring myself to bubba the lines after spending as much as i did on these darn calipers. I would have been ok with their condition if the distribution block hadn't snapped . Thanks though.
Old Oct 21, 2007 | 04:47 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Cut the old lines off at the block, right at the top of the fitting. Use a regular 6-point socket on the fitting. They'll turn right off with a bit of pressure.
Old Oct 21, 2007 | 05:08 PM
joehalford01
good idea, i think you saved me alot of trouble when i get all my parts in. thanks!
To ahhhhhhh!!!!!!!!!
