502 into 69 vette?
Old Oct 21, 2007 | 04:12 AM
jboweriii's Avatar
jboweriii
Default 502 into 69 vette?
had a 427 in it... will my hooker super comp headers bolt up to the 502, thanks
Old Oct 21, 2007 | 04:19 AM
GDaina's Avatar
GDaina
yep, don't forget to add an electric fuel pump
Old Oct 21, 2007 | 12:10 PM
PRNDL's Avatar
PRNDL
and a new hood!
(If you currently have a stock hood)
Old Oct 21, 2007 | 12:35 PM
Jclgodale3's Avatar
Jclgodale3
rihwoods here on the forum would be a good contact about this for you
Old Oct 21, 2007 | 03:13 PM
rihwoods's Avatar
rihwoods
I'm running Hedman's...only tight spot was tube at steering box..just "dimpled" that....I would think your Hookers would might work......this Hooker part is listed: 2225HKR
ZZ502/502
Rich
Old Oct 21, 2007 | 03:16 PM
kayosnes's Avatar
kayosnes
What kind of 502 are you going to use. zz?
Old Oct 21, 2007 | 06:05 PM
69ttop502's Avatar
69ttop502
As long as you are using heads with the stock exhaust port location, the headers are fine. Like George said, you need an electric fuel pump. Also I needed a new oil pan, the one that comes with the crate didn't fit. Also if you are running a manual transmission, there is no boss for the ball stud for the clutch cross shaft. You need the bracket from Scoggin-Dickey or make your own.
Bill
Old Oct 22, 2007 | 11:26 AM
Skunkvette's Avatar
Skunkvette
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Fuel pump and clutch Z bar were the only issues I had even the Scoogin Dickey bracket needed to be modiofied to fit.
I ran new Hedmans side exhaust headers which fit great. Just needed to grind down flanges for head bolt clearance.
Old Oct 22, 2007 | 12:33 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Skunk
Fuel pump and Z-bar were the easy part for me
By the way, ARP offers lower profile head bolts. I replaced the lower 4 on each side and gained clearance without grinding, using my stock exhaust manifolds. I believe that would have worked for header flanges also, based on measurement taken on my hooker side pipes.
Bullshark
Old Oct 22, 2007 | 12:37 PM
S489's Avatar
S489
Skunkvette, looks great! do you have a parts list for the serpentine setup? looks a lot like what i need! sorry for hijack
Old Oct 22, 2007 | 01:20 PM
Skunkvette's Avatar
Skunkvette
It is a March set up for BB Vettes, if you need the part number PM me and I can look them up. Be advised - it is not a cheap date! I was floored when I got the pricing, but in the end the set up was easy to install, and very well made.
Old Oct 22, 2007 | 01:24 PM
Skunkvette's Avatar
Skunkvette
Very sharp Bullshark! Bet that baby rocks!
Old Oct 22, 2007 | 02:04 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Skunk, I too am interested, PM me the info if you will. Did the crank pulley fit without notching the crossmember?? I have the proverbial c hair clearance right now A while back, I was thinking about setting up a MSD crank trigger wheel but that wouldn't fit.
Bullshark
Old Oct 22, 2007 | 08:50 PM
GDaina's Avatar
GDaina
And me...
Old Oct 22, 2007 | 08:55 PM
GDaina's Avatar
GDaina
Bill
Not a problem with the pan, the one I got was too deep, kept scraping the bottom. Replaced it with a Moroso road racing pan.
Old Oct 22, 2007 | 10:11 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
I did the same thing with RamJet George.
Old Oct 23, 2007 | 06:43 AM
Skunkvette's Avatar
Skunkvette
March part number for drive set up was 20511. A/C with P/S.
I swapped to the Milodon 7 quart oil pan, no problems with clearance although the dipstick was fun!
To 502 into 69 vette?
Old Oct 23, 2007 | 06:55 AM
crazywelder's Avatar
crazywelder
The block casting has a boss in the correct location for the cross shaft, you can also just drill and tap a hole.
Old Oct 23, 2007 | 07:37 AM
GDaina's Avatar
GDaina
Hoover....have you installed the motor yet? That looks like it's too far back. The pivot ball should be before the filter
Old Oct 23, 2007 | 08:30 AM
crazywelder
I take back my comment, you are correct, I was in error. That location works for chassis other than Corvette's. Sorry. I installed that 502 in a F body.
