air gap or torker 2 ??
Old Oct 22, 2007 | 10:10 PM
chris75stingray's Avatar
chris75stingray
Default air gap or torker 2 ??
while choosing parts for my 383 rebuild i originally planned to use an edelbrock performer rpm airgap intake which has a dual plane and 1500-6500 rpm range. but my cam ,a comp cams xr288hr10 has a rpm range of 2500-6000. so i thought maybe i should get a torker 2 which is a single plane and a rpm range of 2500-6500 which matches my cam better.
will the torker 2 be a better match for my cam? would the single plane or double plane intake be better?
thanks
Old Oct 22, 2007 | 10:32 PM
1fastC3's Avatar
1fastC3
go with the air gap provided youve got the hood clearance, it will flow enough for you engine, if you want a higher flowing intake you may want to look at a better single plane(such as a victor jr.) as opposed to the torquer two, ive asked about the T2 at various speed shops and nobody has anything positive to say about them.
-alex
Old Oct 23, 2007 | 08:42 PM
thecorvette's Avatar
thecorvette
The edelbrock RPM or RPM Air-Gap intakes would probably be the better choice in my opinion.
Old Oct 23, 2007 | 09:50 PM
Roughrider's Avatar
Roughrider
I say go with the Air-Gap. You'll get better idle quality and better performance at lower rpm's. The small loss of upper rpm horsepower is worth the better overall driveability.
Old Oct 23, 2007 | 10:41 PM
chris75stingray
yeah. i know the dual planes run better at idle and low rpm , but i wasn't sure if it would have a negative affect because the cam starts at 2500. airgap is what i'll get. thanks again
To air gap or torker 2 ??
