Tpi Vss
Old Oct 23, 2007 | 12:46 AM
77 vette's Avatar
77 vette
Default Tpi Vss
I need to get a VSS for my 77 (90-91 TPI) TH350, I was looking at this one-
http://cgi.ebay.com/ebaymotors/90-92...ayphotohosting
I'm confused at how these work because of different gear ratios in the rear end and transmissions of different type cars, also wouldn't tire size be a factor? I have a 336 rear with 25 1/2" rear tires. Thanks
Old Oct 23, 2007 | 12:50 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Give Fuel Injection Specialists a call they are in Texas and are very helpful. They have a pretty god website toohttp://www.fuelinjection.com/
Old Oct 23, 2007 | 03:56 PM
Rotonda's Avatar
Rotonda
Are you going to be running an electronic speedometer in your 77? If not, the only real function your VSS will perform is to help your ECU differentiate between idle, car-at-rest and idle, car-coasting. These two states have different requirements and the VSS signal is there only to keep your engine from stalling. The quantity of signal (i.e VSS "reading" 30 mph when vehicle is going 50 OR 20 mph is not important). Please go the JAGS THAT RUN website and get the TPI swap manual - its good reference.
Old Oct 23, 2007 | 06:15 PM
KENS80V's Avatar
KENS80V
That is the correct VSS for your application. You first need to deal with getting the correct combination for the speedo to work correctly with your rear tire and gear selection. If you are using the stock gears and tire size then just hook up the VSS to the tranny then the speedo cable to the VSS. We can advise you on which driven and drive gears to buy to make your speedo accurate if you have changed gear ratio or tire size. There is a great calculator available for that online if you search.
Old Oct 24, 2007 | 04:27 AM
77 vette's Avatar
77 vette
Thanks, obviously (man I hate trying to spell that word) I've got more research to do.
Old Oct 24, 2007 | 04:41 AM
77 vette's Avatar
77 vette
No
That makes sense. I had that book untill I left it laying around. The Wife has a 2 day laying around period until it gets dumped in the trash and She's **** about this (Well not **** but you understand what I mean) and I'm a cheap bastard that hates spending money on something that's already bought
Old Oct 24, 2007 | 04:59 AM
77 vette's Avatar
77 vette
Thank you. This is what I was trying to get at. My speedo has been off sense the new rear gears and tires where put on. I know I need a new gear for the trans and will try and synchronous them prior to this car coming out of the garage with the new TPI.
To Tpi Vss
