Strange brake problem
Old Oct 23, 2007 | 12:42 PM
Vettkeeper's Avatar
Vettkeeper
Default Strange brake problem
I am having a problem figuring out what is wrong with the brakes on my 78. Here’s what happening; when applying the brakes slow and steady no problem breaking is great. When I hit the brakes as in a hurry to stop, the front end pulls hard and dips to the left for a slip second then straightens out and finishes stopping just fine. The car has had a complete body off restoration, all new front end components, bench bled new master cylinder, all new brake lines, new combination valve, DOT 5 brake fluid, and re-built calipers from Van Steel. I have bled the brakes and the pedal does not pump up as if there is any air in the system and the pads are organic. Any ideas??
Old Oct 23, 2007 | 12:44 PM
SIXFOOTER's Avatar
SIXFOOTER
might be a little air in the right side. small bubbles in 1 line will make that brake a little weaker than the other side
Old Oct 23, 2007 | 12:49 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
How is the wheel alignement?
Could also be a flow restriction in the line to the right side of the front. I'd make sure that the line hasn't been crimped, especially under the frame in the front. This was a favorite spot for Bubba to jack up the car.
Old Oct 23, 2007 | 01:28 PM
C3BB4SPD's Avatar
C3BB4SPD
Also, while you're down there check to be sure you didn't get anything on the rotor or pads...like oil or grease maybe. (It's will likely be on the right side, but you may want to check both sides just to be sure. Road grime can cause brakes to react funny sometimes, so the culprit could be on either side.)
If you do find something, use a good brake cleaner like CRC Brakleen on both the rotors and the pads, and wipe it off with a lint free cloth. Cleaning the pads will require pulling the caliper.
Old Oct 23, 2007 | 01:29 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If that's DOT 5 silicone fluid, you need to purge it completely from your system and start over with any quality non-silicone fluid. Silicone fluid is compressible and only good, supposedly, for long term storage. May or may not solve your problem, but this is an issue you should address if your Vette is a driver.
Old Oct 23, 2007 | 02:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Huh? Just pull the pins and lift the pads out of the top of the caliper.
Old Oct 23, 2007 | 04:20 PM
Blue Seducer's Avatar
Blue Seducer
Same problem with my 82. All new calipers & pads. All was fine for about 400 miles. Now pulls left while braking and to right while not braking. Right caliper draging?
Old Oct 23, 2007 | 04:25 PM
Vette Crazzy's Avatar
Vette Crazzy
i agree, silicone is no good. put it in my dads 63 impala, backed out of the garage and almost went over the hill. purged it all out filled with regular dot 3 and it stops on a dime
vc
Old Oct 23, 2007 | 05:17 PM
Steve439's Avatar
Steve439
Silicone will work fine - it just needs to be bled completely.
I've used nothing but silicone for 15 years.
Something is restricting braking for a moment on one side.
I agree with the previous comments of possible kinked hose or sticky caliper.
Old Oct 23, 2007 | 05:26 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
I know this seems too simple, but lets eliminate the easy ones. Try pumping the brakes up several times at the pedal with your foot then right way hitting it hard and see if it still pulls. If it does it is not air in the lines. Thenb we need to pull the tires and check each front caliper for corrohsion around the brake pistons. Although this is less likey as they usually stick and stay stuck - it is possible.
My best guess is the air.
Another thought have a look underneath and make sure the suspenmsion components are tight (grab a hold and give them a tug see if they have a lot of movement).
If it is air in the system, let me know, I have a decent vaccum pump set up to bleed brakes with and do not live fr from you
Old Oct 23, 2007 | 06:40 PM
TheSkunkWorks
Sorry if this proves to be a sidebar from the real problem at hand, but silicone brake fluid is compressible and there have been complaints that it is difficult to completely bleed 100% of the air from it. I can't vouch for the latter issue, because the first one has always been enough to dissuade me from ever using it. Also, it doesn't mix with other fluids. If you're among those who believe in it, it's your right...
Old Oct 23, 2007 | 06:43 PM
C3BB4SPD's Avatar
C3BB4SPD
Is that easier??? I always thought it was simpler to pull the two bolts holding the caliper than pull the pins. JMHO
Old Oct 23, 2007 | 08:05 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There's only one pin, and I have my caliper bolts loctited in place. To make it a bit easier, I use a hitch pin in the hole at the end of the pin rather than the factory doohickey whose name I've completely forgotten at the moment.
Old Oct 24, 2007 | 01:05 AM
TheSkunkWorks
Batman, "doohickey" is an appropriate technical term with me.
BTW, if anyone finds they have those lousy dual pin calipers, I'll take them off your hands, no questions.
Old Oct 24, 2007 | 01:43 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Cotter pin.
Old Oct 24, 2007 | 12:05 PM
Vettkeeper's Avatar
Vettkeeper
Thanks Guys, I've checked front end components and the calipers are all new, as are all of the brake lines and pads. I never really was comfortable with the DOT 5 silicon brake fluid, it was harder to bleed than other types and getting all of the air out of the system took much longer as the fluid seems to have a higher viscosity then the DOT 3 fluid. I will re-check for air again, but am really considering purging the brake system and going with a DOT 3 brake fluid. I’m thinking I’ll open the bleeder screws, let them all drain at the calipers, refill with DOT 3, gravity bleed them one at a time until only DOT 3 fluid comes out, then pressure bleed to make sure all the air is out.
Thanks again
To Strange brake problem
