She's Bleeding!!!!
Old Oct 23, 2007 | 11:42 PM
Cosmo Kramer's Avatar
Cosmo Kramer
Default She's Bleeding!!!!
Finally, got the block, heads, and crank back from the machine shop yesterday and started putting her back together around 1:00 today. If all goes well, everything should be buttoned up by the weekend!!
Old Oct 24, 2007 | 12:24 AM
Jclgodale3's Avatar
Jclgodale3
Nice build. Never have to much assembly lube. Are the pistons Hypers?
Old Oct 24, 2007 | 09:38 PM
Cosmo Kramer
Jclgodale3..........Yes, they are.
Old Oct 24, 2007 | 10:02 PM
Jclgodale3's Avatar
Jclgodale3
Cool...and 30 over at that
Old Oct 25, 2007 | 12:15 AM
Solid LT1's Avatar
Solid LT1
Looks like you will have some SERIOUS compression ratio there with the domes and the 186 Heads. Hope your cam is big, my 1970 LT-1 dosen't care much for our 91 octane "premium" fuel in California. I need to add booster or 20% racegas to allow 34-6 degrees of total timing in my Vette.
Old Oct 25, 2007 | 11:03 AM
Cosmo Kramer
Solid LT1.............Other than being 30 over, the pistons are stock replacements (L46 350/350.) As such, the compression ratio is 11:1. To eliminate pinging, I add one gallon of race gas (octane 110) to 15 gallons of 92 non-oxygenated unleaded. I'll set the total timing at 36 degrees and back off from there, if needed.
Old Oct 25, 2007 | 11:27 AM
Cosmo Kramer
Solid LT1.............I think your ratio of 20% race fuel is correct. By adding three gallons of 110 to 13 gallons of 92, the overall octane rating bumps to 94.5. Because of worn cylinder walls (hence lower compression ratios) before the rebuild, I'm guessing that the one gallon of 110 to 15 gallons of 92 was sufficient. If memory serves me correctly, GM recommended gas with an octane rating of 95 or better for the L46 & LT1.
Old Oct 25, 2007 | 11:35 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You're looking great!
Old Oct 27, 2007 | 09:29 PM
Cosmo Kramer
Due to an unrelated delay, the engine goes back in on Monday.
Old Oct 27, 2007 | 09:44 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Nice looking work there. Should be lots of fun when you get it all back together. Keep the pics coming as it is a nice clean looking build.
Old Oct 29, 2007 | 08:57 AM
GD70's Avatar
GD70
BEAUTIFUL! It's a work of art!
Glenn
Old Oct 29, 2007 | 09:26 AM
69vettester's Avatar
69vettester
Man Ive never seen anyone bust their knuckle that bad just torquing some main bolts ..Looks like it was alot of fun..whens the startup?
Old Oct 29, 2007 | 09:12 PM
Cosmo Kramer
Old Oct 30, 2007 | 05:03 AM
77 vette's Avatar
77 vette
It looks like a crime seen. The title is a little twisted but it got my attenshion.
QUOTE=69vettester;1562507677]Man Ive never seen anyone bust their knuckle that bad just torquing some main bolts ..Looks like it was alot of fun..whens the startup?[/QUOTE]
To She's Bleeding!!!!
