Strut rod question
Old Oct 24, 2007 | 04:33 PM
vette blue's Avatar
vette blue
Default Strut rod question
Hurray! got my strut rods off without having to cut anything!
But now my vbp poly bushings don't want to go in the strut. In the photo you can see a shiny sleeve. Is that sleeve supposed to be removed so that the bushing goes in? Or do I really have to force it in.
Old Oct 24, 2007 | 04:41 PM
Scott Marzahl's Avatar
Scott Marzahl
That is part of the old bushing, you need to press it out.
Old Oct 24, 2007 | 04:43 PM
vette blue's Avatar
vette blue
Thank you!
Old Oct 24, 2007 | 05:10 PM
Stroker-427's Avatar
Stroker-427
Default Strut rods...
..... VBP Smart Strut Rods...... the best value for money for your rearend!
Will change the rear swing-arm lenght, will reduce the camber gain...... and will dramatically reduce the infamous jacking problem of any C3 Corvette!!!!
Stop working with your hammer...... and start work with your Credit Card !!!
Old Oct 24, 2007 | 05:31 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
Old Oct 24, 2007 | 05:37 PM
vette blue's Avatar
vette blue
Trying to keep her more or less original.
Have been trying to hammer away at those sleeves and they won't budge.
Also tried the vice with a socket still no luck.
Is there any other way to do it at home without taking it to a shop with a press??
Old Oct 24, 2007 | 05:46 PM
Stroker-427
Default Keep....
.....of course..... is a good thing to keep a nice hystorical car as much original you can!
But..... nobody tell you that you have to trow away you original strut rods....!
keep it in the garage...... and install the new one.....!!
Remember...... the Smart Strut Rods are one of the most "Hystorical" thing you can bolt in your car....... was one of the first suggestion of a man named...... Dick Guldstrand!
.....enough "Hystoric" man ?
Only my opinion, of course!:o
Old Oct 24, 2007 | 05:52 PM
Stroker-427
Default ...sorry....
I finished the message withouth to give you an idea to disassemble your Struts!!!
From the pic you have posted, it looks that your problem is to pull-out the outer sleeve of the original rubber grommet...
Try to make one cut on it, with a hand saw from the internal.
The sleeve should become elastic..... as a spring..... and then you shold be abe to press it out with a small effort!
..... try it!
Old Oct 24, 2007 | 06:10 PM
Red 69's Avatar
Red 69
I agree with the above, put a hacksaw blade inside the strut end and cut the remaining bushing through. It is rust seized to the strut, the cut will relieve it and it will come out with you hammer method.
Old Oct 24, 2007 | 06:13 PM
vette blue's Avatar
vette blue
..... try it!
Ingenious!!!!
I'll try it tonight.
Honestly I'd love to put on the smart struts but after forking out for Bilsteins and bushings (which I'll hopefully finish tonight) I've kinda met the monthly budget. But then again it's Only 7 days to November.
Thanks again
Old Oct 24, 2007 | 06:16 PM
Stroker-427
Old Oct 25, 2007 | 09:12 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
There are two different size eyes on strut rods, depending on the year. My Energy Suspension kit came with both the old (small) and new (large) bushings.
Old Oct 26, 2007 | 01:45 PM
vette blue's Avatar
vette blue
..... try it!
Many thanks Stroker 427, They came out like butter after sawing Feels a lot tighter when driving it. While working on it I noticed my trailing arm bushings are shot. I guess that will be my winter project.
Old Oct 26, 2007 | 05:42 PM
Stroker-427
Happy for you !!!
To Strut rod question
