Brakes barely working
Old Oct 25, 2007 | 10:54 PM
Ironcross's Avatar
Ironcross
Originally Posted by defsegx
I know these cars didn't stop well stock, but this is crazy. I'm afraid to drive it honestly.
Any ideas?
Thanks!
-Josh
That statement is positively not true. You obviously never drove one when new. Who knows what some of these cars have been through the last 30 or so years and your worried what it will cost. The alternative might be what will it cost if you cant stop it the way it should?
Old Oct 25, 2007 | 11:05 PM
neuroclast's Avatar
neuroclast
Well I am 23 so you are very right I never drove a 1979 car new. My statement was based on comments made by people I know who did. I apologize if that statement offended you.
And yes, I am worried what it will cost. Saying I shouldn't is simply ignorant. I don't see a cage in your 62, what would happen if it got hit or rolled? You see there are lots of factors which cause people to not make things as safe as they should be, and in my opinion my cost concerns are probably more valid than your appearance or originality ones.
But at any rate, I am going to take it and have it looked at. Thank you for your comments.
Old Oct 25, 2007 | 11:18 PM
pbcanney's Avatar
pbcanney
In my 12 years with mine, I have replaced all the calipers, mc and booster and recently installed russell braided lines
I have found the best method (for me) to bleed the brakes with 2 people is to have the person on the pedal press and hold while I release the bleeder(s)
press hold release
press hold release
right rear
left rear
right front
left front
the pump pump pump hold release thing doesnt seem to work on mine.
engine off
press hold release
Old Oct 26, 2007 | 10:32 AM
neuroclast's Avatar
neuroclast
Took it to Midas and had them bleed it, no help and $57 more down the drain heh.
Old Oct 26, 2007 | 01:12 PM
VTcivil's Avatar
VTcivil
I bought a pressure bleeder and that solved my problem. I also went with a new MC. My origional issue was the pedal dropping to the floor. I als upgraded to braided stainless flex lines.
If you are sure this thing is bled, then you could have a bad booster ony your hands like mentioned by others. You also might want to pull the MC and bench bleed it, then you will need to bleed the whole system again.
Old Nov 16, 2007 | 10:11 PM
Mia's Avatar
Mia
I took mine to a local mechanic that my wife has used for years. $120 for a new caliper, and $30 in labor and the brakes are perfect now.. Looks like one of the calipers was locked. Source of squeaking and spongy feeling...
Old Nov 17, 2007 | 08:58 AM
phclub's Avatar
phclub
New England Events Coordinator
Default 3 bleeders on rears??
Originally Posted by RATT7
Hi, I had the same problem last month. I checked around for leaks and there where none at all. I know that over time the rear brakes may get air into them via the seals. I purchased a set of Russell speed bleeders from Summit and installed them on all four calipers. The rear calipers need 3 bleeders each. I had a problem last year bleeding the brakes on my 1970 buick, I needed to take care of the bleeding of the 1980 vette and wasent looking forward to it. Everyone suggested the speed bleeders and I swear by them, once installed I had all 4 calipers bleed in under 15 min and that solved the soft pedal that I had. Start with the speed bleeders and bleed the whole system, that should resolve the problem.
Hi, I have just purchased speed bleeders for my 70 vert. I purchased 2 each for the rear, am I missing one. My understanding is the rears had two each.
Old Nov 17, 2007 | 09:41 AM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
I had the same problem with my 76 when my mom owned the car and we never figured out what the problem was. I bought the car from her a couple years ago and decided to just replace the entire brake system with a complete kit from VB&P and guess what? I had the same problem with the new setup minus the proportioning valve. When I say I replaced everything minus the proportioning valve I mean everything. New lines, rotors, MC, booster, o-ring calipers, braided flex lines, hawk pads……….. I am talking the works here and I still had the same problem. Anyways I got all the new stuff in and even bought the power bleeder and the brakes still felt mushy. It turns out that it was the adjustment rod between the booster and the MC that was not adjusted correctly. I am not sure if you are having the same problem but its worth a shot. Now that I have the brakes working fine I am going to replace my proportioning valve but that isn’t till next spring.
Old Nov 17, 2007 | 10:23 AM
schmegeggie's Avatar
schmegeggie
Has the car been sitting?
I went through the same thing last year. Turned out one of the rear calipers was letting air into the system when pumping the brakes. All the bleeding in the world wouldn't fix it. As a result, I bought new O-Ring calipers, rubber lines, new MC. Bled 3x around and...wella! Brakes that work!. Finding the source of the air is the issue. If you have thoroughly bled and still don't have a good pedal, then air is coming back into the system, you've got to find the source. It may not even be leaking fluid, mine wasn't, makes it even harder to find!
Good Luck!
Old Nov 17, 2007 | 11:16 AM
Mike Ward's Avatar
Mike Ward
Don't take this the wrong way, but if you're stretched financially to the point you can't afford to take the car to a discount garage to have them work on a primary safety system, you might want to park it until the money issue resolves itself.
You shouldn't be driving it if the brakes are not 100%.
Old Nov 17, 2007 | 12:07 PM
schmegeggie
A 20 year-old kid at a muffler franchise isn't going to have the understanding of these cars' brake system. I'll give you my address if you just want to throw money out the window.
You must systematically look into each part of the system and find what the issue is. If you can't do it yourself, or don't have the time or money, you probably bought the wrong car. If you're loosing your patience, then walk away from it for a few days and come back to it with a fresh mind, that always works for me. These cars are 35+/- years old, they have problems, it's that simple. Fixing it is part of the fun, and when your through, the feeling of accomplishment is second to none. Not to mention what you learned.
Good Luck!
Old Nov 17, 2007 | 01:20 PM
TPI BOY's Avatar
TPI BOY
How do you ajust the rod and how do you get to it
Old Nov 17, 2007 | 03:31 PM
  #33
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
If the pedal is mushy you have air in the system.
Remember power brakes ALWAYS feel mushy.
If you can pump it up and it stays up with your foot light ly on the pedal, you have air in the system
if you pump it up and the pedal slowly sinks, you have a leak or a bad MC
If you can't pump it up you have a bad MC
If you pump it up and pedal still goes to the floor, check the push rod as stated above. It should have just a tiny bit of play, like the thickness of a piece of paper.
(lie on your back and look up under the dash. it's that rod you can hardly get to that moves when you move the brake pedal)
Old Nov 17, 2007 | 03:55 PM
  #34
TPI BOY's Avatar
TPI BOY
Can you get to the rod by removing
the master cylinder and ajust it that way
Old Nov 17, 2007 | 04:00 PM
  #35
Former Vendor
That you be a whole lot harder.
The MC needs to be in place and fully tightened to adjust the pushrod ( for a manual brake car )
For a power brake car there is an adjustment sometimes on the rod from the booster to the MC. If that is out of ajdustment.
Old Nov 17, 2007 | 04:44 PM
  #36
TPI BOY's Avatar
TPI BOY
I have a 75 with power brakes so I just unbolt the
master and seperate and turn the rod so it
is longer is that all
Old Nov 17, 2007 | 05:22 PM
  #37
C3BB4SPD's Avatar
C3BB4SPD
I'm not positive how the Corvette brakes operate since mine are working fine and I haven't had reason to get into them yet. But I just had a similar problem bleeding my '67 Chevelle with a Master Power 4-wheel disc set-up (80-85 Cadillac Seville), and it ended up being the emergency brake adjustment. Until the e-brake adjusters for the rear pads are properly set-up against the rotor, there is no way to get them to bleed properly. But like I said, I'm not sure it's the same on the Corvette, so take it with a grain of salt. I'm only suggesting it because I haven't seen it mentioned...and I know (first hand) how frustrating brake issues can be, especially when you think you've already tried everything else. Good Luck!
To Brakes barely working
Old Nov 17, 2007 | 06:17 PM
  #38
Former Vendor
Unfortunately Corvette Emergency brakes are a different universe ( an alternate evil parallel universe)
One more trick I just remembered.
This only works on Rubber flex lines and only as a last resort.
DO NOT do this with stainless Braided!
Clamp off all four flex lines with vice grips. You have to squeeze the line pretty good. All 4...
press on the brake pedal. It should be rock hard (power brake people have the engine running)
If it's not you have a bad MC or a leak or air in the lines.
unclamp one line at a time. See what happens. Re clamp the line, try another wheel.
Keith
Old Nov 17, 2007 | 06:25 PM
  #39
tomnt's Avatar
tomnt
The parking brake is seperate on this car. This sounds like a power booster problem.
Old Nov 17, 2007 | 06:42 PM
  #40
neuroclast's Avatar
neuroclast
Sorry for not posting back. I got the system sorted out and it's working well now. 3 of the calipers were leaking, so I replaced all 4. One of the front lines was bulbed so I replaced the front 2. That didn't fix it, so I replaced the MC and now it's great. Had a friend help me bleed them (pump pump turn etc), and she is as good as I can expect. I guess it was a combo of the calipers being screwed and the MC, but now with a mostly new brake system she stops fine.
Thanks for all the advice!
-Josh
