Serpentine conversion for a 78 with BBC
Old Oct 24, 2007 | 11:50 PM
vetteguy112233's Avatar
vetteguy112233
Default Serpentine conversion for a 78 with BBC
I've read just about all of the serpentine conversion threads on here, but I have a few questions about modifying my 78 with a 502.
It looks like some people had to modify their crossmembers of their 80-82 Vettes and one post mentioned that maybe 78-82 have to be modified.
Does anyone know for sure if I will have to modify my crossmember.
The other question has been asked, but does anyone know for sure what vehicles can be used as donor vehicles for a serpentine kit? My boss recommends a 93 or newer Suburban that had a BBC in it. He found thiese items in a local junk yard for his 77. He says the 93's have less brackets and are easier to install.
Any suggestions for what cars/trucks to look for in the wrecking yards?
Old Oct 25, 2007 | 07:53 AM
L88Plus's Avatar
L88Plus
The only problem I see with using GM's brackets is that they're cast iron and very heavy. You might check - the small block changed brackets when they went to Vortec engines. Other than the A/C swapping sides, there are a few changes. You might look under the hoods of both to see if big blocks did the swap as well.
Old Oct 25, 2007 | 08:12 AM
Durango_Boy's Avatar
Durango_Boy
I have some Gen6 454 brackets and they are cast iron and very tall.
I think someone has had better luck modifying the aluminum small block brackets to fit a big block.
Old Oct 25, 2007 | 08:43 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
All GM BB kits put the AC compressor and alternator to high to clear the hood. There are instructions on the net that show how to mod the SB brackets to fit a BB. March has a direct fit Serp drive system that will fit your car with no mods, so does Street and Performance. The cross member mod comes into play when you go with the front mount compact system where all accessories are mounted in front of the engine.
Neal
Old Oct 25, 2007 | 10:08 AM
Durango_Boy
Have you maybe saved a link to this? I would be interested to know how to do this.
Old Oct 25, 2007 | 10:11 AM
vetteguy112233
I'm not going to run A/C so I don't have to worry about that, but I do have the crank, water pump, power steering and alternator. Right now the alternator is on the drivers side, but I'm looking to Procharge the motor soon, so I want to move the alternator to the passenger side in hopes of making enough room for the Procharger unit.
Old Oct 25, 2007 | 10:15 AM
Durango_Boy
The A/C cradle can be modified very easily to accept an alternator. The small block GM serpentine brackets will fit under most stock hoods. I suggest modifying a set of small block brackets, moving the alternator to the passenger side, and installing an idler pulley on the driver's side until you get your Procharger configuration figured out.
Old Oct 25, 2007 | 07:01 PM
chevymans 77
DB I don't have the link right now but I may be able to locate it again. I'll try and find it and post it latter tonight
Neal
Old Oct 25, 2007 | 07:47 PM
Zychron's Avatar
Zychron
I think this is the link you are looking for:
http://www.fidnet.com/~harleyms/serpentine%20page.htm
I will not clear a stock hood or an L88 hood as configured.
If you are going to Procharge, go with this:
http://www.marchperf.com/pg58b.html
It is compact and they have a setup for a Procharger.
Old Oct 25, 2007 | 08:46 PM
Chris Johnson's Avatar
Chris Johnson
The March system Zychron posted a link to looks very nice!
I think the determining factor on whether you need to modify the crossmember is whether the accessories mount in front of the block or not. This March system would most likely require x-member modification. March has another system (wide-mount I believe) that does NOT require mods.
Old Oct 25, 2007 | 10:04 PM
vetteguy112233
As nice as the March system is, it's way too expensive. I think I'm going to get a serpentine setup from a 93, 94 or 95 Chev with a BBC and hope it all fits.
Old Oct 26, 2007 | 12:03 AM
Zychron's Avatar
Zychron
Sorry but it won't.
Old Oct 26, 2007 | 02:30 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
...March has a direct fit Serp drive system that will fit your car with no mods, so does Street and Performance...
By "direct fit" are your referring to a V-to-serp belts and pulleys only conversion?? That's what I was looking into, but March never replied to my questions/inquiry (wanted std. ratios, separate AC, w/o PS).
Old Oct 26, 2007 | 02:20 PM
iree75's Avatar
iree75
I can understand if you want to make your own and save a few $$.. I wanted to keep my a/c and p/s with a minimal of issues. The march system will bolt up without modifying your cross-member and it looks beautiful. Plus it does not tie into the exhaust manifold making header install way easy.. Here is the 427 i built in my 75.
Old Oct 26, 2007 | 07:11 PM
1982CorvetteDude's Avatar
1982CorvetteDude
I've seen a "kit" on ebay that contains the plates pre-cut to adapt GM SB brackets to a BB.
Old Oct 26, 2007 | 08:37 PM
chevymans 77
Its a total system, complete swap over to serp. not a pulley change.
Neal
To Serpentine conversion for a 78 with BBC
