most common power drain
Old Oct 26, 2007 | 08:27 PM
goldengoat2's Avatar
goldengoat2
Default most common power drain
I have a 78 and it has a power drain, whats the most common cause for this. Thanks
Old Oct 26, 2007 | 09:29 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Maybe not the most common...but....if the little switch for the light in the glove box is not adjusted right, it will leave the light on AFTER you close the door. You will never know it. I accidently discovered mine in the dark garage one night. This was after 3 or 4 batteries over 2 or 3 years. It will kill the battery in a couple of days. I was always charging my 72. Fixed the switch!
Old Oct 26, 2007 | 09:43 PM
goldengoat2
thanks, I will look
Old Oct 26, 2007 | 09:51 PM
Les 94 Comp Yellow's Avatar
Les 94 Comp Yellow
Check and make sure the battery ground cable has a good clean contact to the post of the battery. That fixed my battery problem .If you don't run the car regularly the battery will drain aqbout 1% per day on it's own. Put a trickle charger on the battery and away goes your battery problem.
Old Oct 26, 2007 | 10:24 PM
SIXFOOTER's Avatar
SIXFOOTER
Timer for the interior lights, alternator, alarm...
Old Oct 26, 2007 | 11:11 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Also, mine will drain down after a couple of weeks of sitting and I've been told it's the clock.
Old Oct 27, 2007 | 12:28 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
As you're seeing from responses, having a small power drain doesn't necessarily indicate something is wrong. If you're not going to crank more often than every couple of weeks or so, a Battery Tender may be in order.
Old Oct 27, 2007 | 12:49 AM
wombvette's Avatar
wombvette
This, and the alternator diodes, with bubba puting the ground on the wrong post on the starter a close third.
Old Oct 27, 2007 | 03:32 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
When I first got my vette, my battery would drain within 2 or three days, found the the T top alams system was shorted somewhere, pulled the alam fuse and never looked back. Semper Fi Bob
Old Oct 27, 2007 | 07:14 AM
bt57's Avatar
bt57
had 3 corvettes with the same problem, if the alarm horn is disconnected (this is how bubba repairs the alarm system) make sure the fuse is pulled
Old Oct 27, 2007 | 10:14 AM
GaryS's Avatar
GaryS
Once you find the source of your battery drain, you ought to consider a battery disconnect. Anytime you are dealing with 30+ year old wiring, you run the risk of fires. Battery disconnects are quick, one minute or less, and cheap, less than $30. Great piece of mind knowing that your car won't burn to the ground due to a short, no battery drain, and even offers a small sense of security since the bad guy has to figure out why the car won't turn on.
Gary
Old Oct 27, 2007 | 05:27 PM
markdtn's Avatar
markdtn
plus clock.
Old Oct 27, 2007 | 08:39 PM
goldengoat2
Thanks folks, alot of good stuff to check, My last vette also had a drain,(66 427, 425 hp) a car I could afford when I was 21 (1981) but not now!
To most common power drain
