T-Top adjustment?
Old Oct 27, 2007 | 08:49 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Default T-Top adjustment?
I just bought some new t tops off of another 78 to replace my cracked ones. The weatherstripping and all is new compared to my old ones. I am having problems getting the rear slide post to line up (the shaft that locks into the rear when you close the handle) I have loosened all the nuts on the inner posts and the handle and tried to adjust it around, and it is still off by about a 1/4 inch. I can put a lot of pressure on the top and it will go in and lock but I feel like the glass is under a lot of stress and is going to break on the first bump I hit. The car hasnt been hit or damaged in any way, is there another adjustment I am ovelooking? can you adust the pillar slot on the front as there is no adjustment I can see on the rear?
Old Oct 27, 2007 | 08:58 PM
Artsvette73's Avatar
Artsvette73
Did you loosen the two screws at the rear where the pin goes into?
Old Oct 27, 2007 | 09:36 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
yes, but there is virtually no play in it. I dont know if its just because the gaskets are new and is making it hard to compress. I have screwed the latch almost all the way in. Just not wanting to make a 600 dollar mistake to find there is another way.
To T-Top adjustment?
