1972 Corvette I'm missing a part and what is it?
Need your help please.
I own a 1972 Corvette 454 Four Speed with air.
I took photos of my compartment where the Jack is stored.
There is a relay not sure the purpose, a 2 white wire and a 1 Yellow wire 2 prong connector that is supposed to plug into a______?
vadelsohn@cogeco.ca
vadelsohn@cogeco.ca
Former Vendor
I would replace them both simply because the relay can go bad and drain the battery. If this happens, I'm willing to bet you won't even remember it's back there and a potential source for the drain.
We had issues in a 76 we built. Car had a new harness installed so we knew the wiring wasn't hacked. Took us a while with an ammeter to track the drain down. Turned out to be that relay.
Autozone.........ask for a turn signal flasher and a horn relay for a 78 Corvette.
(Not sure that you need the relay.A correct numbered alarm relay could cost you big bucks,why dont you try yours and see if it works.The horn relay for the 78 will replace the alarm relay for the 72 but you might have to switch 2 wires in the connector but I dont think so.)
I have the same key hole on my '73 and it opens the trunk.
Yes, that should be how you engage the alarm. Later models have it over the driver side front wheel.
Bah.... you blew my fun
I almost pissed myself when I read the post by VTcivil
Sorry all, couldn't pass this opportunity up
