Double pumper vs Vacuum
Old Oct 30, 2007 | 08:11 PM
Sweet's Avatar
Sweet
Default Double pumper vs Vacuum
650 double pumper or 670 vacuum secondary.
I'm putting it on a stock 350/300 HP, alum. manifold, 4 speed, 3.08 rear
Old Oct 30, 2007 | 08:59 PM
b71vette's Avatar
b71vette
I recommend the DP with the 4 speed, vacuum with an auto
Old Oct 30, 2007 | 10:07 PM
trw's Avatar
trw
With your rear gears, you need the vacuum.
It will bog otherwise.
Terry
Old Oct 31, 2007 | 03:31 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
You really will not see a performance gain. It will dump more gas too quickly than you will be able to use with your current set up.
Old Oct 31, 2007 | 08:22 AM
Ganey's Avatar
Ganey
If you drive hard & want a double pumper, 600 would be a better match for your setup.
To Double pumper vs Vacuum
