Steering Cylinder 81 vette
Old Oct 30, 2007 | 09:09 PM
BERIN's Avatar
BERIN
Default Steering Cylinder 81 vette
Trying to rebuild my steering cylinder but can not get the end of the cylinder off the relay rod assembly after I have removed the cotter pin and nut, need a little help?
Old Oct 30, 2007 | 11:37 PM
sjmaster's Avatar
sjmaster
I heated mine SLIGHTLY with a torch, put a sacrificial nut on the end, tap tap tap...popped loose. I had a time with the connection to the idler arm....here I used heat and a mini machinist steel wedge....popped her right off.
Old Oct 31, 2007 | 10:56 AM
steve228's Avatar
steve228
Default Re:Steering Cylinder
I used a Handy Ball Joint Seperater from AutoZone,and a BFH.
A few whacks and it popped right off. Hope this helps.Steve
Old Nov 1, 2007 | 12:12 AM
BERIN's Avatar
BERIN
Thanks the ball seperator and some heat worked:
Old Nov 1, 2007 | 02:39 AM
done4fun's Avatar
done4fun
can you rebuild those or better off with new...i know the ps box leaks like heck also.im picking away at this car and will take the advice from this forum to do so.
ken
Old Nov 1, 2007 | 08:48 AM
chuck d's Avatar
chuck d
I rebuilt mine a few seasons ago. An easy task I might add. It stopped leaking for awhile, but eventually I ended up replacing it with a new unit.
To Steering Cylinder 81 vette
