oil weight question
. That's my .02
Instead a very good all round oil (but expensive as well...) is the valvoline fully sint comp 5/60 (too heavy for my personal taste anyway...)
I hear all these good things about Rotella being good for our Corvette engines. My question is, is 15W-40 a good weight to use? Does it even come in any other weight than that? I am about to put a new motor in and will soon care about the oil I use (lets be frank, before it didn't really matter what I put in there...I was burning it anyways)...is this a good choice for a good oil to use? Just wondering...
There are people with alot more knowledge than me that are recommending Diesel rated motor oils for these old cars. Engineers etc. Rotella is one of them. I have been using them for a while now with no problems.
I am trying the 20/50 for this next raod trip round turkeyday (about 900 miles)
http://www.lucasoil.com/products/dis...tid=3&loc=show
here are the specs
http://www.lucasoil.com/images/media...0_plus_oil.pdf
LUCAS MATERIAL SAFETY DATA SHEET
Lucas Racing 20/50 Plus Racing Oil Product Number: 20500, 20501, 20502, 20503
CHEMICAL AND PHYSICAL PROPERTIES --- SECTION II
Chemical Name: Petroleum hydrocarbon plus additives.
Formula: Proprietary information.
Components: Hydrotreated distillate, heavy paraffin, solvent dewaxed distillate, zinc, copper, calcium,
and magnesium detergents.
Hazardous Components: Zinc, copper compounds. Oil mist if generated.
Appearance: Liquid. Color: Clear brown Odor: Characteristic petroleum.
Vapor Density (air = 1 ATM): Greater than air.
Boiling Point: >500°F.
Viscosity cSt @ 100°C: Greater than or equal to 16.5
Density: 7.462 pounds/gallon
Specific Gravity @ 60°F: .8961
Solubility in Water: Negligible @ 25°C.
Stability: Stable under normal conditions of storage and handling.
Incompatibility: Avoid contact with strong oxidizing agents.
Check out theire full product list here
http://www.lucasoil.com/products/index.sd
