How wicked is your cam?
Old Oct 31, 2007 | 03:29 PM
540 RAT's Avatar
540 RAT
Default How wicked is your cam?
In between beers at your next bench racing session, and just for fun, check your cam specs, and see how they stack-up in tech author David Vizard's "Advertised Overlap Chart" below:
10* - 40* towing
30* - 60* ordinary street
50* - 75* street performance
70* - 90* street/strip
85* - 100* race
95* - 115* Pro race
Here's how you calculate your advertised overlap:
Now compare your adv overlap to the chart above, to see how wicked your cam really is. Most people think their cam is hotter than it really is, so don't feel bad if you are in that group, since you will not be alone. This can give you an idea of what to shoot for on your next rebuild
Old Oct 31, 2007 | 03:38 PM
S489's Avatar
S489
mine is about 60 degrees, but is a hydraulic roller which is supposed to be better in this area right?
it sounds pretty mean at idle, but smooths out quickly off idle . . . wouldn't want any wilder on the street!
The Money Pit's Avatar
The Money Pit
Mine checks in where I thought (Street/strip) as it was picked from a circle track grind list.
But "wicked" it may be in a 350....same cam in a 406,...not so wicked.This tread I expect to go on for quite a while.
Old Oct 31, 2007 | 03:43 PM
Gordonm's Avatar
Gordonm
74 here. Solid flat tappet cam. Street/strip. Right where I should be.
Old Oct 31, 2007 | 04:11 PM
LFZ's Avatar
LFZ
67 for the 383.
Old Oct 31, 2007 | 04:15 PM
Vette Crazzy's Avatar
Vette Crazzy
i ran a solid roller in my 385 cu in 61 belair
648/627 lift
270/280 dur @50
97*
sounded wicked
and yes it was streetable
5500 convertor and 4:71 gear in a 4000# car
vc
Old Oct 31, 2007 | 04:32 PM
Edzred72's Avatar
Edzred72
The chart numbers for the first three clasifications overlap as much as ten degrees...so I'm a "tweener". Could be either ordinary or performance street.
Eddie
Old Oct 31, 2007 | 04:36 PM
1fastC3's Avatar
1fastC3
66 for me, i had better get a bigger cam when i go to build a 383 in a few years, right now its a mechanical flat tappet, perhaps a mechanical roller is in my future.
-alex
Old Oct 31, 2007 | 05:49 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have not had a chance to run the cam yet but the one in my LS conversion is a 61 by your method listed.
281+289=570
570/4=142.5
142.5-112=30.5
30.5*2=61
Old Oct 31, 2007 | 06:12 PM
Lee H's Avatar
Lee H
77 here
Old Oct 31, 2007 | 06:18 PM
tristan69's Avatar
tristan69
I rate at 81 in my 383.
Wicked enough to set of every car alarm on the block as I pass.
Harleys do the same thing.
Old Oct 31, 2007 | 06:37 PM
OzzyTom's Avatar
OzzyTom
Edelbrock #2207 hydraulic roller in a 383.....
.... comes in at 85.5
And I thought it would be good for towing
Old Oct 31, 2007 | 06:52 PM
gkull's Avatar
gkull
That is just one of the many errors and just outright faulty thinking by author David Vizard.
Just to prove the point go to the Comp Cams list of cams PDF for small blocks. They give a bigger advertised duration number for H-flat street cams than some pure racing solid roller. The .050 number puts all cams a somewhat level playing field except for the very fast lobe lift solid roller cams
You look at it another way, compare his book with Smokey Unick's book on how to hotrod small block Chevys. You are talking 35-40 year old ideas.
Old Oct 31, 2007 | 07:15 PM
540 RAT's Avatar
540 RAT
648/627 lift
270/280 dur @50
97*
sounded wicked
vc
97*........SWEET, a really nasty lope is music to my ears.
A buddy of mine had a 93* adv overlap cam in his big block, which had such an awesome lope, that it would turn all heads at the local cruise-in. Now he has an adv overlap of 85.5*, and it sounds positively tame, nobody looks, but it still runs 9.9's at a buck forty. I'm setting up the 540 I'm building with an adv overlap of 90*, which I'm expecting to sound pretty good.
It appears that a really awesome chop starts at right around 90* adv overlap, so hopefully I'll have enough to turn heads too.
GKull, I guess the laws of Phyics don't care if the idea is decades old or not. Lots of overlap gives a good chop, always has, always will
Old Oct 31, 2007 | 08:53 PM
gkull's Avatar
gkull
I guess you did not understand. Right off the comp cams web sight the Solid roller XR280R has an advertised 280/286 The Magnum flat tappet 280H is 280/280
They are both 110 So they score within a one point or so. That is just wrong. H flat of 230/230 @ .050 does not run like 242/248 @ .050 solid roller
Old Oct 31, 2007 | 09:06 PM
shafrs3's Avatar
shafrs3
Unless the engine's displacement figure is set to one value the results are useless.
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I would agree with the chart for fat tappet cams, roller cams are a whole new ballgame, much higher lifts at lower durations are the main reason for putting one in
To How wicked is your cam?
Old Oct 31, 2007 | 09:16 PM
Deakins's Avatar
Deakins
I have to agree that duration @50 is one of the better ways to judge cams. Mine came out to 103*, kinda cool; about what I thought the solid roller would come out to be.
Old Oct 31, 2007 | 09:18 PM
Steve439's Avatar
Steve439
Eddie
Me too. Right where I want to be...
Old Oct 31, 2007 | 09:41 PM
84rzv500r's Avatar
84rzv500r
95.0 for my ho hum GM crate motor
