Wheel alignment question!
Old Nov 1, 2007 | 02:04 PM
sly vette's Avatar
sly vette
Default Wheel alignment question!
I would like to take my '69 in for an alignment and I was wondering if the factory specs are sufficient or should I give them other numbers to shoot for? I had an alignment done months ago and I was happy because it did away with a lot of the front end wander. But now I see that all the desire for the car to drift on the straights is still there. Any suggestions???
This car has all new parts after a nut and bolt resto.
Old Nov 1, 2007 | 02:06 PM
TWINRAY's Avatar
TWINRAY
Whatever you do, ask anyway for a "before" and "after" printout. Both sides should be the same and make sure they do rear tow (which is a beech).
Old Nov 1, 2007 | 04:07 PM
jbroughton's Avatar
jbroughton
What TwinRay said
Here's the alignment specs that VB&P recommends - http://www.vbandp.com/instructions/h...ruct/align.htm
Old Nov 1, 2007 | 04:27 PM
76stingracer's Avatar
76stingracer
Originally Posted by jbroughton
Have then hit those numbers or as close as possible but the key item to tell then is to make the numbers equal side to side. if they can only get 2 degrees of caster on one side then they will have to make the other side 2 degrees.
Old Nov 2, 2007 | 10:25 AM
sly vette's Avatar
sly vette
Those are the numbers I was looking for thanks!
After getting the drivers wheel truly parallel with the center line of the car, I then got the right side wheel parallel with the left side. Bingo zero toe and it rides with no darting.
Caster and camber are good!
Thanks guys!!!!
I did get it up to 90 mph with no shake what so ever.
The only down side to this is that the State Police are the ones that told me I was doing 90mph.
He wrote me up for 75 in a 55.
Wow I never had a speeding ticket before.....I think I will look at this as an honor....After all I had to get a Vette before I could speed and have fun at it !!!!
Mark
Old Nov 2, 2007 | 12:31 PM
boat196's Avatar
boat196
Can someone post alginment spec's, that their using and any feed back. I 'm looking for information to establish a base line for my alignment spec's.
Old Nov 3, 2007 | 12:11 AM
73 LS-4's Avatar
73 LS-4
Bob,
The alignment specs will differ depending on your use of the car. For example if you punch in the numbers I run on either of my C3's in for the stock alignment specs just about everything will come out red (out of spec). the reason being that I set up my cars for handling far more then tire wear. I work at a tire shop, with two great alignment techs that work for me. So I normally stay late at work when Aligning my cars for an autocross event. Now if you want your car setup as a pretty aggressive street setup I can give you the specs I run, but there will be some tire wear, especially the inside edges since I run a good amount of negative camber front and rear. Be aware that any alignment shop that says they can align your car in less then two hours hasn't done many C3's correctly. I don't think I've ever had one out of the shop in less then two hours, and these are cars with all new parts. Some I've had take up to three hours with all good but older parts. So expect to pay good money for a good alignment.
Pat Kunz
Old Nov 3, 2007 | 11:04 AM
sly vette's Avatar
sly vette
Follow the ADVANCED STREET specs in post 3 from VBP for a good baseline!!!
Worked great for me!
Good Luck!
Old Nov 4, 2007 | 02:03 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Good Luck!
Have you noticed any "dartiness" or wandering in your steering with that 0* toe spec?
Old Nov 4, 2007 | 06:02 PM
jyounane's Avatar
jyounane
Good Luck!
I run the same and have set up 5 C3's this way. I add a little front toe to remove the risk of dartiness.
Joe
Old Nov 4, 2007 | 08:37 PM
sly vette's Avatar
sly vette
Very, very little on some of the rougher roads.
Overall I enjoy this set up very much!
Mark
To Wheel alignment question!
