1979 Brake Light Problem
Old Nov 5, 2007 | 02:54 PM
79vette90's Avatar
79vette90
Default 1979 Brake Light Problem
My driver side brake light has been acting very strange. Sometimes it works, and sometimes it doesn't. When it's not working, if I turn on the driver side directional and then step on the brake, the brake light will work until I use the passenger side directional. Once I use the passenger side directional, the driver side brake light stops working. So far I have cleaned the ground connection to the frame, replaced the socket and replaced the bulb. I'm looking for any other ideas on what could be causing the problem. Thanks for any help you can give me.
Old Nov 5, 2007 | 04:18 PM
72LS1Vette's Avatar
72LS1Vette
All of the wiring for the brake and turn signals goes through the turn signal switch. The fact that the brake light works after operating the signal switch one way and doesn't when it operates the other way suggests that you might need a new switch. Fortunately they're not that expensive but they are a bit of a pain to install.
Rick B.
