Sleeves / No Sleeves
Old Nov 6, 2007 | 08:42 AM
dannyman's Avatar
dannyman
Default Sleeves / No Sleeves
Alright guys, need your help!!
Removed original A-arm bushings which were rubber with steel sleeves inside and out. Received new poly bushings without sleeves!!
Do I need the metal sleeves with the poly bushings?
If so, do you know which suppliers have them and would they be specific to rubber/poly?
Thanks Dan
Old Nov 6, 2007 | 12:42 PM
S489's Avatar
S489
check with your vendor, mine (poly) came with sleeves and instructions for how to set up correctly. . .
Old Nov 6, 2007 | 02:27 PM
BB68Vett's Avatar
BB68Vett
Most poly bushings come with new metal sleeves AFAIK. Some will say leave the old ones in. I recently replaced my sleeves. You will probably be OK not to replace them, just make sure they are smooth inside and the poly bushings should not be loose.
Old Nov 6, 2007 | 02:42 PM
jackson's Avatar
jackson
CA bushing (both rubber & poly) has 3 parts:
Steel Outer Shell
Rubber or poly bushing.
Steel Inner Sleeve.
OE bushing is bonded ... rubber bonded to both shell & sleeve.
Aftermarket Poly bushing Not bonded ... all 3 parts are separate.
If you removed old shells from your CA ... you need new ones.
If you did Not remove old shells from your CA ... and you're using POLY bushings ... you can reuse (clean) old outer shells and reuse (clean) old inner sleeves.
Old Nov 6, 2007 | 04:57 PM
dannyman's Avatar
dannyman
Steel Outer Shell
Steel Inner Sleeve.
Thanks to all for the responses. Obviously I need to follow up on this!
Old Nov 6, 2007 | 05:10 PM
Stroker-427's Avatar
Stroker-427
Check ID of your poly bushings....... and you will know for shure if you need the sleeves!!!
If yes....... you have to clean it very well..... remeber that the rubber flex and plyurethane slide!!!!!
A very very clean inner sleeve if essential..... plus a bit of silicon grease!!
To Sleeves / No Sleeves
