Odd fuel pressure problem.
Old Nov 6, 2007 | 02:36 PM
pbcanney's Avatar
pbcanney
Default Odd fuel pressure problem.
This one is really driving me crazy
My 81 has an electric fuel pump in the rear. When I first start the car, there is a solid 6 psi of pressure at the carb. Slowly, though within a 1/2 hour of running, the pressure drops eventually to near 0. It affects the running of the car, from nice to 'I can tell it's gasping for gas'
I changed the fuel pump (Holley Blue regulated) to a Holley Red and removed the regulator. But the same issue remains.
The hoses don't look decreped. So I'm struggling for answers. Is this normal for a Holley pump?
disclaimers:
yes, I know it should be on a mechanical pump, but the cam is missing in the timing chain cover and I don't have the time to tear down the front of the engine for the next 6 months (immenant house move)
yes, there's a kill switch
Old Nov 6, 2007 | 03:09 PM
SIXFOOTER's Avatar
SIXFOOTER
Stupid question, but are you sure the pump is running? It may be sucking the sock in the tank into the tube, the rubber line at the tank may be collapsing. Stuff to look for
Old Nov 6, 2007 | 03:23 PM
540 RAT's Avatar
540 RAT
Couple things:
1. Check to make sure the fuel tank vent is working as it should. I'm not sure what kind of smog stuff is on an 81, but try leaving the gas cap unlatched. Put a rag or something around the opeing, something that can vent. Then try to drive so that you don't slosh fuel too much, if you can, and see how she does. It sounds like you may just have a vent issue. Its worth a look.
2. Traditional Chevy's don't have a fuel pump cam behind the timing cover, that's why you never saw one. Its on the cam itself, so you have it there right now. If you want to switch to a mechanical fuel pump, all you need is the pump and its pushrod. Then sort out the fuel line as needed.
Old Nov 6, 2007 | 03:48 PM
pbcanney's Avatar
pbcanney
Originally Posted by 540 RAT
Couple things:
1. Didn't even consider this! Great idea. I'll try it this weekend.
2. Must be from my mopar days I'm dragging this around with me. DOH! I'll be ordering up the mechanical pump and rod toot sweet.
Yes, I can hear it running, but, what is this sock you speak of? Of all the things I have done with cars, pulling inards out of gas tanks has only been my experience on air cooled VW's.
I assume it's a filtering part? In the tank? On the pickup tube? Do I need it if there is a filter before the pump (which is right behind the Corvette nameplate at the rear.
Old Nov 6, 2007 | 03:55 PM
SIXFOOTER's Avatar
SIXFOOTER
This thing is on the end of the pickup tube in the tank.
http://www.ecklers.com/product.asp?p...4&dept_id=1275
There is a rubber tube connecting the pickup tube to the frame rail fuel line, it may be collapsing inside. Good point 540 RAT made about the vent, drive it around until its failing and then open the fuel cap, if its related to the vent it should go to running fina again with the cap off.
Old Nov 6, 2007 | 04:02 PM
rihwoods's Avatar
rihwoods
I think these pumps are "gravity pumps"..they "push" fuel,not suck from tank.....is your pump under the tank ???
Old Nov 6, 2007 | 07:31 PM
pbcanney's Avatar
pbcanney
Its level with the bottom of the tank, but the feeder comes from the top of the tank on mine (I think)
Old Nov 7, 2007 | 11:00 AM
mooneyd's Avatar
mooneyd
The 81 has a computer controled carb, better check if going to a mechanical pump will screw up the computer. Make sure the fuel filter is not clogged. Good luck.
To Odd fuel pressure problem.
