Weight difference LSx vs L82
Old Nov 6, 2007 | 11:38 PM
hill3335lilo's Avatar
hill3335lilo
Default Weight difference LSx vs L82
Does anyone have any data on how much less the LSx (LS2 in my case) engine weighs than an L82? What would be the total differnece for an L82 with an auto trans versus LS2 with TKO 5sp?
Thank you for your help.
Dave
Old Nov 7, 2007 | 10:17 AM
70 LS1's Avatar
70 LS1
I found a chart online that lists the standard small block as 575 lbs and the LS1 as 460 lbs.
Old Nov 7, 2007 | 10:52 AM
hill3335lilo
Thank you for the information. Has anyone actually weighed the front and rear of the cars after this conversion to see how the balance has changed? Those numbers would be interesting as well.
thank you.
Dave
Old Nov 7, 2007 | 11:00 AM
rihwoods's Avatar
rihwoods
I think a fully "dressed" L-82 weighs approx 620 Lbs less tranny..the Borg Warner Super T-10 weighs 92 Lbs...
Old Nov 7, 2007 | 12:58 PM
70 LS1's Avatar
70 LS1
thank you.
Dave
I don't have any real numbers for you, but after I did the engine swap, T56 swap, removed the soft-top frame , and removed the spare tire & tub, I sat about 1" higher in the front and rear.
To Weight difference LSx vs L82
