cant decide ? 383 or zz4
Old Nov 7, 2007 | 04:21 AM
kanngaroo jack's Avatar
kanngaroo jack
Default cant decide ? 383 or zz4
Well i cant make up my mind , so im hopeing you guys can, Going into a 80 l48
Old Nov 7, 2007 | 06:31 AM
Rotonda's Avatar
Rotonda
Why not 'compromise' and get a zz383/393HO ftom GM?
Old Nov 7, 2007 | 08:11 AM
Durango_Boy's Avatar
Durango_Boy
If you're gonna go for the gold, you might as well do it with spirit fingers.
Old Nov 7, 2007 | 08:24 AM
Ganey's Avatar
Ganey
Old Nov 7, 2007 | 09:30 AM
breathial's Avatar
breathial
ALWAYS go with more cubes.
Old Nov 7, 2007 | 09:50 AM
TopGunn's Avatar
TopGunn
I vote for 383. I have a ZZ4, great engine, runs like a clock but it's a pig. I ended up replacing the heads and cam to make it go down the road better. Cost me allot more $$ in the long run. I was in the same position as you and made the wrong choice for my needs.
Old Nov 7, 2007 | 09:52 AM
Durango_Boy
GM ZZ383
http://www.gmhorsepower.com/ZZ_383.html
Old Nov 7, 2007 | 10:28 PM
firefighter's Avatar
firefighter
If you don't care about matching numbers just take the block it's a 4 bolt right? Make it what you want a forged 383ci rotating assy can be had relatively cheap and you can make it the exact compression you want put a Vortec topend on it with and RPM Airgap and your cam of choice with the carb you want. 500 hp and comprable TQ is attainable. Just be ready with the trans and the rear they might wanna go boom if not up to the task.
Hell you can build a 396 these days out of a SBC 350
Old Nov 7, 2007 | 10:36 PM
willem wallace's Avatar
willem wallace
Default Premium 383
Check out Gilbert Chevrolets Premium ZZ383/425 part no. SC383PE
Old Nov 7, 2007 | 10:53 PM
MakoShark72's Avatar
MakoShark72
TG, I have a ZZ4 as well, not installed yet. I got it for a deal, around $2600. What exactly did you do to yours and what power/torque increases, and how much$$. I might be interested in mods before I install the motor??? Not to hijack the thread, you can PM me if you want.
Thanks!
Old Nov 8, 2007 | 12:08 AM
vettenoir's Avatar
vettenoir
I replaced a ZZ3 with a 383 and my vote is for the 383
Old Nov 8, 2007 | 06:11 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Thanks!
You can't beat cubes, I'd probably go with a 383 if I had to do it over again. Having said that, my modified ZZ4 (GM's Hot Cam, Manley race-flow valves and springs) isn't doing too bad however. Last time at dyno I got 328 RWHP, and it runs in the 12's.
Old Nov 8, 2007 | 11:03 AM
steve228's Avatar
steve228
yeah,"Spirit Fingers" rofl:
To cant decide ? 383 or zz4
