Help.... can't decide on which cam
but they also had lead in their fuel.
I've heard this debate before..... iron heads can make similar/better power, but need a higher octane fuel to prevent detonation.
Besides, of any two equally prepared, equally powered C3's, the one with aluminum heads is always going to corner better and get to the other end of the straightaway first due to the roughly 75 lb. advantage. So it kinda makes this debate moot.
Upon further searching and reading I have found a custom ground cam with 218/224 @.050 with a 112 lsa and lift of .605in/.600ex. Recommended Beehive springs. I'm concerned that this will be too much lift for the pistons. What think you? TIA
shmoky
shmoky
edit - Better give me the specs all in one place so I've got it right. I'll need advertised (seat timing) duration, sinse this calc doesn't extrapolate from @ .050" data, and installed ICA or installed advance. Engine specs needed are bore, stroke, rod length, head cc, gasket thickness, gasket dia, deck height, and piston dome/dish volume.
shmoky
BTW, with all the cam talk over the past month or so, I did some more modeling on my 496 and I've decided to change my own specs recently - different firing order and going one step larger down both the intake and exhaust lobe charts. Now it's so close to 2008 that I'm waiting to see if any new profiles come out that may interest me.
Adv. dur. 282/290
dur. @.050 231/239
LSA 110* ICA 106*
link to cam specs http://static.summitracing.com/globa.../lun-60212.pdf
Engine Specs.
bore: 4.2817
Stroke: 4.00
rod length: 6.135
Head cc: 104
gasket thickness: .040 compressed? (FelPro)
gasket dia: .4370
deck height: .025 (guestimate)
Piston head volume -13.80cc
Hope these are the numbers you need.
shmoky
PS here's another cam
http://www.holley.com/data/Products/Technical/50268.pdf
Last edited by shmoky; Nov 23, 2007 at 06:19 PM. Reason: added second cam spec link
Adv. dur. 282/290
dur. @.050 231/239
LSA 110* ICA 106*
Engine Specs.
bore: 4.2817
Stroke: 4.00
rod length: 6.135
Head cc: 104
gasket dia: .4370
shmoky
Anyway, without beating around the bush, I'm not going to start advocating lousy quench clearances for even the mildest of perf engines, so let's skip those scenarios as moot.
If your current CR is 10.3:1, bringing the quench down to .040 - .045" is going to raise your CR to between about 10.75 - 10.85:1. With the Lunati 282 installed at 106* ICA or even retarded to 110* (straight up), the resulting DCR's (in the 8.5:1 range) are much higher than I recommend for your combo on pump gas.
Installing a cam with more duration which closes at 73* ABDC would yield a DCR of between about 8:1 - 8.15:1. That sitll leaves you a bit higher than I'd personally be comfortable with, given the iron heads, w/o assurances from a real expert. And, keep in mind that longer duration valve timing increases the likelihood you could encounter streetability issues, and that as you shift the power band upwards cylinder pressures at higher rpm's can increase significantly. Suggest 112* LSA, if not wider, should you head this direction.
IMHO, on the street with those heads you need to reduce that static CR by decreasing piston dome volume and/or increasing combustion chamber volume, correcting the quench in any event. Kind of a pickle... BTW, a set of aluminum heads with 110cc chambers (i.e.: Edelbrock Performer RPM 454-O's) would actually put your DCR's on the low side with that 282 stick, and if you can swing a set you'd be looking to earlier IVC timing, bigger domes or some milling to get it back up. (10.25 - 10.5:1 would look to be about golden with those heads and that cam.) That's the safer side of this curve to be on.
I know it's not all good news, but FWIW I hope it helps you get your build optimized.
Charlie
Charlie
If you are @ 10.3 actual comp and .040 quench looks like this cam http://www.holley.com/data/Products/Technical/50268.pdf which has an intake closing point of 73 degrees ABDC and an LSA of 114 is a great choice. Bigger quench or higher compression makes you have to move up in duration to maintain correct DCR. The above cam will be very streetable with your drivetrain and a 454 but looks like you have 2 options to attain that. Different pistons or different heads. Don't go with more quench to drop compression. The other way to go is more duration which will affect streetability although with your setup you might be able to go 1 step bigger and still be happy with streetability. Go back to the drawing board. Those heads are originally 109 CC. Have they been surfaced .030?. In stock configuration they would be alright with your setup.
