no lighting behind dash...help?
Old Nov 9, 2007 | 11:25 AM
Beefs's Avatar
Beefs
Navigator
Default no lighting behind dash...help?
I am not getting any illumination behind my speedo, tach, and center guages. All gages are functioning, and circuit boards look fine....any ideas would be apprecdiated.
Old Nov 9, 2007 | 02:13 PM
c3corvettes's Avatar
c3corvettes
Default It's annoying to drive at night!
I have the exact same problem that you have on my '80. Let's wait and see if someone can shed some "light" on us!
Enrique
Old Nov 9, 2007 | 02:14 PM
Clue's Avatar
Clue
Bulbs?
Old Nov 9, 2007 | 02:58 PM
jdp6000's Avatar
jdp6000
I have no ideal what year car you have. But if you have a dimmer on the headlight switch its probably the coil in front that controls that function that is broken. Once the coil breaks you illumination will not work.
Jim
Old Nov 9, 2007 | 03:01 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
The headlight switch is the VERY FIRST part of the diagnostic chain here.
Old Nov 9, 2007 | 03:07 PM
jdp6000's Avatar
jdp6000
Part broken looks like (the coil thing) this and is replaceable
[IMG][/IMG]
Its in the white casing at the front of the switch...hard to see...look close
[IMG][/IMG]
Old Nov 9, 2007 | 03:30 PM
sly vette's Avatar
sly vette
Old Nov 9, 2007 | 03:44 PM
Clue's Avatar
Clue
[IMG][/IMG]
[IMG][/IMG]
Interesting. My 1974 is also all dark and I presumed the bulbs where out.
Those are a little hard to get at so I have not checket yet.
So it's probably the switch.
Great info
Old Nov 9, 2007 | 06:21 PM
Nvts's Avatar
Nvts
On my '68, the lights normally do not come on until I turn the dimmer all the way till it clicks, then back it back off. Would that be coil too?
Old Nov 9, 2007 | 06:53 PM
jdp6000's Avatar
jdp6000
Yes. Where the coil is broken determines when the lights go on. Example if its at the beginning...you will get some dimmer function. If its at the end you need to turn the **** until it gets pasted the broken point. My guess is your coil is broken just before the full on position.
Another thing if you are noticing your lights are getting dimmer but still work it means the coil is burning out and getting thinner.
Cheap part. Ecklers has it about $19. Or the whole switch for i think $59.
This part. You can't see the coil. its on the otherside.
Jim
Old Nov 9, 2007 | 07:17 PM
guitarcrazy02's Avatar
guitarcrazy02
Maybe it's just a blown fuse? My 81 did that a few months ago and it scared the crap outta me. Checked under the dash and the fuse was burned through. Put a new one in and it's been fine since.
I'd check that before ripping anything else apart.
I bet it's just that.
Old Nov 9, 2007 | 08:59 PM
Nvts's Avatar
Nvts
Jim
My searchFu must be getting weak. I only see the whole part at ecklars, or the Headlight Dimmer Switch, but it does not look like the one you put up a pic of.
Old Nov 9, 2007 | 09:11 PM
...Roger...'s Avatar
...Roger...
Check the small instrument fuse first.
Old Nov 10, 2007 | 09:14 AM
guitarcrazy02
What year is the car? I'll tell you right where it is if it's got the blade style fuses.
Top of fuse block, all the way on the left. It'll say 7.5 on it.
Old Nov 10, 2007 | 10:18 PM
c3corvettes
My fuse is good on my '80. How do you change the switch?
Enrique
Hey Paul how are you doing...
Old Nov 11, 2007 | 01:07 AM
Beefs's Avatar
Beefs
Navigator
Default thanks all
man....been out of town and cant believe the responses...the car is a 79...my headlight switch has been acting up...(ie the pully is stripped and able to pull right out) very tough to activate headlights. i will check fuse tom as well and get back....thanks again all for the ideas
Old Nov 11, 2007 | 08:37 AM
...Roger...
Enrique
Both of you before you go throught he hassle of changing the switch you should test to see if the switch in fact is not working.
To Test-put a test light on the "inst. light fuse"(check both sides of fuse to be safe)-pull headlight switch out-rotate **** both ways and watch the test light-If it lights up and dims and brightens as you rotate the **** then it is not bad.If it tests OK then you have a wiring problem not a headlight switch problem.
To no lighting behind dash...help?
Old Nov 11, 2007 | 09:44 AM
mmrdl's Avatar
mmrdl
Default No Dashboard Lights
I have the same problem that is being described here on my 1917. I have to get across the fuse yet to see if that is the problem. If not is there a thread that describes how to get to the replacement part that is mentioned here.
Any info will help.
I meant 1971
Old Nov 11, 2007 | 09:56 AM
...Roger...
Jim
No coil on this part.
Originally Posted by Nvts
These are headlight dimmer switches not dash light dimmer coils.
Old Nov 11, 2007 | 09:59 AM
...Roger...
Are you referring to the headlight switch or the dimmer switches that are not related to the dash light problem?
