Wiring Harness excange
Old Nov 11, 2007 | 05:56 PM
janbanan24's Avatar
janbanan24
Default Wiring Harness excange
I'm rebuilding my motor on my -79 Vette.
...so I started looking at the engine bay, and found some trouble with the wiring.
The harness that goes from the fuse-panel across the fire wall, and on the right side devides into starter and AC connections has one cable that seems to have been shorted or something, since it has melted itself and some surrounding cables.
Any ideas, or tips and tricks, things to keep in mind here?
All input is very welcome!
Old Nov 11, 2007 | 08:51 PM
jim2527's Avatar
jim2527
First you need to figure out what that wire is for. I cant help as I only have wire schematics for my '70.
After you figure out what its for everything else should fall into place.
Old Nov 11, 2007 | 09:05 PM
markdtn's Avatar
markdtn
It is working on 30 years old now. Might not hurt to replace it. Engine harnesses are not nearly as expensive as dash harness. Try 'Lectric Limited harness through The Last Detail.
Old Nov 16, 2007 | 01:24 PM
janbanan24's Avatar
janbanan24
Ok, thanks for the tip! I did not kow of that company!
...this might be an idiot question, but how do I know if I have an AUX-fan?
Old Nov 18, 2007 | 02:26 PM
janbanan24's Avatar
janbanan24
Seriously, theese wiring harnesses for -79 vettes are with or without aux-fan.
Now, I know that my car has an AC but what is the aux-fan and how do I know if I have one or not?
Old Nov 18, 2007 | 02:41 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
same wire was burnt on my 78 when I got it. I ordered a new starter extension harness and the ac harness. Found out the ac harness was a back order everywhere I went but I finally called Doc Rebuild and they had one, its on the way now. I have tried rewiring parts of the car but gave up and just started ordering the harnesses. the ac harness should cost you about 140 bucks.
Old Nov 18, 2007 | 09:56 PM
71406's Avatar
71406
I didnt replace my wiring harness when the motor was out of the car and regretted it later. Do it now its much easier.
To Wiring Harness excange
